I need to replace the window washer fluid in a 2010 Camry
I purchased a 2010 Toyota Camry in Florida and have to take it to New York. The washer fluid in the car, was for Florida and will not take the temps in New Yor.
Is there a way to replace it without removing the tank?
Check your air filter,may be clogged up.Here's a video on replacing the air filter,check Walmart for the best prices. Tutorial 2010 Toyota Camry Air Filter
the washer pump is located in the bottom of the washer fluid bottle , so where you top up the washer fluid that is where you need to get to they are usually accessed by removing the wheel and inner wheel arch liner then the pump can be pulled from the fluid bottle
As your windows usually are slim jim resistant so its more prudent to get locksmith to open and could make new set of lost keys using vin number, make, model, year.
Yes, certain 2010 Toyota Camrys were involved in both the sticking accelerator pedal and the floormat recalls. ---------------------------------------------------------------------------------------
The sensor inside the tank is defective or covered in goo. Remove the sensor from the tank or remove the tank and flush it clean with hot water and a mild solution of white vinegar, if the sensor still reads the tank is low replace it.
that is just the way the car is built, the newer cars with the aerodynamics set the way they are will have a buffering sound if only front or only rear windows are open, like you said the only way to negate that noise is to open the front windows a crack, its a characteristic of the vehicle, many new cars do that.
