Question about Amana Side-By-Side Refrigerator 26 cu. ft. - ASD2622HR
The water dispenser works fine when i remove the filter. It slows to a trickle when the filter is installed. I have excellent water pressure. Any ideas?
The ice maker works fine. I have tried multiple filters
    Top Expert:
  • Amana Master
  • 34,781 Answers
The filter(s) could be installed backwards. The arrow should point toward the refrigerator, not the water source
Posted on Dec 01, 2012
catriver
  • 878 Answers
SOURCE: No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Posted on Nov 12, 2006
  • 883 Answers
SOURCE: ICE MAKER and Water Dispenser
very likely a partially clogged filter, but not sure why no light.
Posted on Jun 13, 2007
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
codfish124
  • 36 Answers
SOURCE: Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Posted on Dec 09, 2008
rick_chong99
SOURCE: Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
Posted on Dec 11, 2009
What, other than clogged filter, causes water flow blockage in Whirlpool ED25TE?
FYI - Mine actually froze the water in the line.. had to remove the water filter, turn off the ice maker, pull the fridge away from the wall..remove the line from the fridge connection..laid it outside for a few hours until I could blow through it.. re-installed ..all ok..
Jun 08, 2017 | Whirlpool Refrigerators
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
GE Refrigerator Water dispenser trickles
Side like a water supply issue or a kinked line. Good pressure at first then weak pressure after a short time is a restriction in the water flow.
Aug 17, 2012 | Refrigerators
Ge profile refrigerator slow water dispenser
you have a seperate valve for ice maker and water dispenser, though it is possible both could have debris preventing proper water flow, i would check the water pressure you have going into the valve solenoid housing. turn off water to fridge, disconnect the line at the fridge, not in basement at saddle valve. place end of tube in bucket, turn on water. how is pressure? good or slow? if its good, then you probably do need to replace valve solenoid housing. You can NOT clear debris out of these, they must be replaced.
If your water pressure is still not good, either y ou have a kink in plastic water line. Despite having changed saddle valve in basement, if the stem of saddle valve is mounted on bottom half of pipe, debris from pipe is getting into water line and so on. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
May 25, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Water is dispening to slow
check for proper flow and pressure on water supply line
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Jan 29, 2009 | KitchenAid KSRA25CNSS Side by Side...
Amana Side-By-Side Refrigerator 26 cu. ft. - ASD2622HR Logo
85 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
