Question about HP Officejet Pro L7650 Printer
Printer HP 7650
I have power, and screen but can not turn on printer and it is not being recognized by my pc
3 Suggested Answers
  • 102 Answers
SOURCE: 0005FBB6 error
sounds like you need the drivers
Posted on Jun 29, 2009
lookup how to reset the NVRAM on the printer to factory default. On the HP OfficeJet 7680 power on while pressing # and 3 on the keypad.
Posted on Jun 21, 2010
My HP Officejet J3608 All-In-One printer was working fine and suddenly I started geting an error message that it does not recognize the USB port. I tried changing it. Changed the ports. Tried a new Cable...
You need to drain the PC Power.
Turn off PC and Turn off Printer
Unplug the power cable from PC to wall socket.( or surge protector )
Unplug the power cable from Printer to Wall socket ( or surge protector )
Disconnect the USB cable from Printer to PC
Wait for 10 minutes.
First connect the power cable of PC and turn it ON
Once the PC is up and running, Connect the power cord to Printer and Turn on the printer
When the Printer is initialized ( or back to normal screen or stage ) Connect the USB cable to Printer and PC.
It should work.
Regards,
Ron
*Please rate this solution with thumbs up and Testimony on it
Jun 30, 2011 | HP J3680 Officejet All In One Printer
Tip
Bluetooth Connection Guide Part 1
This is a "How To" for Connecting the Nokia Series 60 device (Nokia 7650, 6600, 3650, 3660 etc...) via Bluetooth TM with the Windows Widcomm software used by TDK, Billington, MSI and others Bluetooth USB Vendors. The steps are similar for other Series 60 devices and have been checked with the 3650 and 6600.
1.Pairing the computer and the Series 60 Handset
Pairing is the process of swapping pass keys and setting up a trusted connection between the Bluetooth USB adapter / card connected to the PC and the 7650 handset. Save any files and close any applications you may have been working on.
2. Set up Bluetooth TM on the 7650 by going to the Main Menu, selecting Connect and then Bluetooth.
3. Make sure the Bluetooth option is On and My Phone's Visibility is Shown to all. Remember what is in My Bluetooth Name - or edit it to one of your choice - this is what your 7650 will be seen as by other Bluetooth TM devices.
4. Right Click on the Bluetooth Icon in the system tray, on the menu that appears go to Setup and then click on Security.
5. A window appears and all being well the right hand pane will have your 7650 (titled what ever you have entered into the phone's My Bluetooth Name entry). If nothing appears click Refresh and your phone should then appear. Highlight the 7650 and click Execute Pairing.
6. A window will pop up asking for a PassKey. Enter in a numeric only passkey and click OK.
7. On the 7650 a screen pops up asking you to enter a passkey - key in the same number you just typed into the PC.
8. By default any connections from your PC to the 7650 must be manually accepted on the 7650. You have an option to set up a connection from the PC to your 7650 as authorized, this means when you connect from the PC to the phone it won't ask you if it's ok and will connect automatically.
9. To set it as automatic: On the 7650 in the Bluetooth TM Setting Screen, you joystick right to the Paired Devices screen, highlight the Computer you just paired with and press Options, select Set as Authorized and Yes. You will then see a padlock icon beside the paired device - this device will no longer require manual authorization for connections to the 7650.
Now you should set My phone's visibility to Hidden - so that unknown devices searching won't see your phone. You can still be connected to by any paired devices. Remember to switch it to Visible if you want to pair with a new device or receive a file / business card from someone with an unpaired device.
on Mar 06, 2010 | Cell Phones
Feeder jam in Hp office jet 7650
Can you see any bits of paper sticking out anywhere? If there is no paper simply re-seat the ink cartridge and perform a complete power cycle.
Jun 20, 2011 | HP Office Equipment & Supplies
Replacing HP 7580 all in one scanner fax with HP 7590 all in one scanner fax. I did not have install CD for 7590 so downloaded drivers from HP site. Error message keeps saying that does not recognize...
first Step - Try another USB Cable.. If this does not solve, try the steps below.
Power off the Printer
Disconnect the USB Cable from Printer to PC ( from PC )
Disconnect the power cord of printer frmo wall outlet
Power off the PC
Disconnect the Power cable from back of PC and from wall outlet as well
wait for 10 minutes
Connect the PC power cables to PC and Turn on the PC
When you login to your Desktop, Turn on the Printer
Connect the Cable,
It should get recognised.
Regards,
Ron
Feb 22, 2011 | HP Computers & Internet
0005FBB6 error
Jun 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Hp scanjet 7650 urgent issue...
I am assuming that you're using the XP operating system. If it's another operating system please do tell me.
I see that it's a problem with your software (that came with your HP scanjet). I use a Samsung at home, so I have not used it.
However, here's a tutorial to scan WITHOUT using your HP software
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
Since it's urgent,
Cheers
Jun 03, 2009 | HP ScanJet 7650 Flatbed Scanner
The model is actually discontinued now, but you can download Driver Software and a Manual for the Scanjet 7650 from the HP website:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=uk&prodTypeId=15179&prodSeriesId=434502&lang=en&cc=uk
You can also get Parts information.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | HP ScanJet 7650 Flatbed Scanner
How do i install myhp7600photosmartprinter to my pc
What HP Photosmart 7600 series do you have? it that 7610, 7680 or 7650? you can go the this website and just choose the correct name of your printer...
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=Photosmart+7600
and please choose the right Operating System..
Hope this can help,,,
God bless...
Nov 22, 2008 | HP Office Equipment & Supplies
Hp scanjet 7650 will not close
Played with the installation of the assembly until hatch would close - but then paper still fed in crookedly.
I am going to have to try to get a new roller assembly & see if that fixes the problem.
I am not very happy with the HP Scanjet 7650.
Jun 30, 2008 | HP Office Equipment & Supplies
HP Officejet Pro L7650 Printer Logo
153 people viewed this question
Ben Johnson
