When i open files instead of there saying words for the action it only has a letter
  • 27,725 Answers
What files are trying to open ?
If you right click on the file/s in question you will have an array of oprtions open with where you will be able to select a default program to open among other options if you select properties you will be able to change which program opens these files.
You might not have the software installed on your computer that is needed to open these files.
IE: adobe , directx , win zip ......
Hope this helps
Posted on Dec 01, 2012
How can I fix Microsoft Office Word 2007 for Windows that is opening in code instead of English
Usually if it opens in code its because the format its been saved in is not compatible with Word. Look at the last three letters of the document, if they are not .txt or .rtf word does not see it as a valid word file.
Mar 02, 2015 | Microsoft Computers & Internet
Crossword missing letters
There are 14 five letter words that start and ends with the letter k
http://www.crosswordsolver.org/quicksolve.php?action=search&letters=5&word[1]=K&word[2]=&word[3]=&word[4]=&word[5]=K&word[6]=&word[7]=&word[8]=&word[9]=&word[10]=&word[11]=&word[12]=&word[13]=&word[14]=&word[15]=
Jan 22, 2014 | Computers & Internet
Cant open links
Henry,
You will need to have the program installed on your computer to open the file that you are wanting to open. For ex. If you were sent a word file and you go to open it you would get an error saying the file does not have a program associated with it to open it. You would need to install Word to open the file. What is the file or file ext. you are trying to open?
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 13, 2013 | Dell Inspiron 1525 Notebook
How to save a file in word
You have several choices when saving Microsoft Word files for use on another computer.
1. Ensure that both computers have the same version of Microsoft Word or that the versions being used are compatible with each other.
2. Save the Word document in the format which can be opened on the other computer, i.e. don't save as Word 2007 or 2010 .DOCX if your other computer only has Word XP or 2000 or 2003 - save instead as Word 95 - 2000 .DOC format.
3. If you don't have Microsoft Word on the other computer, install a copy of the free Kingsoft Office 2012 Suite which is able to open and edit all current Word document formats.
Jan 06, 2012 | Computers & Internet
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
Works to Word
Greetings, JGregg7937, and welcome to Fixya.com
This is a fairly common and confusing problem. When you open up MSWord and you click open, I'm sure you can't find your files. Well, this is caused because Word, by default, looks for word's own little files. However, the two are very compatible. Click Open, or File>Open if you will, and click the drop down menu that says File Type and click all files (or you can simply type *.* in the file name slot). Go to the directory in which the file is saved and click open.
I hope that worked out for ya and let me know if it didn't.
Nov 19, 2008 | Microsoft Windows XP Home Edition
Ms word
please ive the clear error message
whts this 'I cannot find ms word at all.........'
May 13, 2008 | Microsoft Word for PC
Word pro lotus millennium edition
Go to the following link
'Start sentences with capital letters' from File-->User Setup-->SmartCorrect Setup.
Cheers - Parveen
Feb 10, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
