Question about Coby TFTV2224 22 in. LCD TV
Antenna cable adapter
Need to get a new antenna cable adapter
  • 2 more comments
  • Beth Boggess Dec 01, 2012
    It is on the tv and all you have to do is screw tour cable line to it. My has burned.
    It has broken
  • Tom Chichester Dec 01, 2012
    That's the F connector on your TV. The TV will have to be opened up to replace it
  • Beth Boggess Dec 03, 2012
    No it is the piece connected to but is on the outside.It is connected to so can hook screw your cable line too.
    Top Expert:
  • Coby Master
  • 34,186 Answers
An adapter to connect the antenna to what?
Posted on Dec 01, 2012
I have a RCA digital amplified indoor/outdoor antenna. I need an adapter to connect the coaxial cable from the antenna to the input on the TV.
Robert, Radioshack/The source any type store like this has the adapter you want. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Attach Coax Plug To TV Aerial Cable
Coaxial Cable Connectors Walmart com
TV Antenna Adapter eBay
Aug 27, 2016 | Envizen Digital Quartet 9 Ed8890a Portable...
HOW TO INSTALL A FM DIRECT ADAPTER ON A 2002 FORD EXPLORER XLT 4X4
You need to find a 'break' in the antenna cable to put the FM direct inline. In SOME cars, if you remove the glove compartment you can see the antenna cable and 2 connectors where it connects inside the dash behind the glove compartment. That is a perfect spot for tying-in the FM Direct. IF not, you have to pull the whole radio out and connect between the radio and the incoming antenna cable. You may need an adapter as almost every manufacturer since GM in 1989 started making their own bastard antenna plugs and jacks instead of the standard universal "Motorola Plug" antenna jack that was used for 40 years, and is used in and out of the FM Direct. Let me know if you need more help.
Jun 15, 2010 | Audiovox Car Audio & Video
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
How do you connect the tv to get a usable signal from the antenna?
What type of antenna? It usually needs an impedance adapter between the antenna and the coaxial cable.
Is the antenna pointing in the right direction? If you're far away you will need a directional antenna set directly into the emitter if you want a good signal .
If you did both and you don't see something then maybe the signal is too weak - get an amplifier and put it between the antenna and the cable.
Oct 25, 2009 | Sony Televison & Video
Replace antenna
Remove old Antenna
  1. Activate the antenna switch to the up position.
  2. Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Gain access to the underside of the area of the trunk where the antenna is located.
  4. Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Remove the mast.
  6. Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Remove the ground lead from the panel.
  8. Pull out the antenna coaxial cable.
  9. Unplug the coaxial from the extension coaxial cable.
  10. Remove the original antenna coaxial cable. Note the route the cable follows.
Install new Antenna
  1. Inspect the fender area where the antenna mast will be mounted for rust.
  2. Clean the area before installing the new antenna.
  3. Plug the new antenna coaxial cable to the extension coaxial cable.
  4. Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  5. Connect the power lead of the antenna to the power antenna lead on the radio.
  6. Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  7. Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  8. Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  9. Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  10. Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  11. Stop the motor after the cable goes into the housing 12 to 25 inches.
  12. Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  13. Replace the retainer nut to the base of the antenna mast and secure tightly.
  14. Replace the panel that covers the antenna mount area.
Oct 16, 2009 | 1996 Honda Accord
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Antenna mast broken
    Give these instructions a shot. Might be too generic but might be enough to get you going. Removing Original Antenna
  1. Step 1 Activate the antenna switch to the up position.
  2. Step 2 Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Step 3 Gain access to the underside of the area where the antenna is located.
  4. Step 4 Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Step 5 Remove the mast.
  6. Step 6 Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Step 7 Remove the ground lead from the panel.
  8. Step 8 Pull out the antenna coaxial cable.
  9. Step 9 Unplug the coaxial from the extension coaxial cable.
  10. Step 10 Remove the original antenna coaxial cable. Note the route the cable follows.
    Installing the New Power Antenna
  11. Step 1 Inspect the fender area where the antenna mast will be mounted for rust.
  12. Step 2 Clean the area before installing the new antenna.
  13. Step 3 Plug the new antenna coaxial cable to the extension coaxial cable. (On some General Motors and Ford cars you may need an adapter to mate the 2 cables together. Car audio retail stores sell such an adapter.)
  14. Step 4 Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  15. Step 5 Connect the power lead of the antenna to the power antenna lead on the radio.
  16. Step 6 Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  17. Step 7 Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  18. Step 8 Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  19. Step 9 Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  20. Step 10 Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  21. Step 11 Stop the motor after the cable goes into the housing 12 to 25 inches.
  22. Step 12 Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  23. Step 13 Replace the retainer nut to the base of the antenna mast and secure tightly.
  24. Step 14 Replace the panel that covers the antenna mount area.
May 13, 2009 | 1993 Chevrolet Corvette
The antenna wire for my IVA-D300 was cut off when i traded my car
the antenna plugs into the brain box there are 2 black cables coming out of your headunit one is the din cable to connect it to the brain box the other is a din cable to connect the noise filter unit
Mar 01, 2009 | Alpine IVA-D300 Car DVD Player
Prong on RCA antenna cable too large for spot on Toshiba vcr/dvd
Hi, You need to look on the cable itself to see if it is an RG58 or RG59 or RG6 or RG9. On an RG6 cable the center conductor is larger than on an RG58, The RG6 cable is used for incoming cable, satellite ect. An outside antenna is not usually equipped with an RG6 unless it is of the new HD variety, which is meant to go to one of the newer tvs. You can remedy the problem a couple of ways, use the ant out on the tv if you have one or use an adapter that fits 2 coax cables together and use a RG 58 jumper from the adapter to the vcr. Good Luck!
Feb 15, 2009 | Toshiba Televison & Video
Antenna replacement
There should be a nut at the base of the antenna or in the car right under the antenna. take that off. then there might be two ways to do it. 1. you might have to run new antenna wire to under the dash board. or the antenna will need the adapter right under where the antenna sits.
Jun 20, 2008 | 1997 Nissan.5 Altima
Coby TFTV2224 22 in. LCD TV Logo
80 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
