Sharp Aquos keeps turning off on it's own
Can you help me. My Aquos LC52D65U tv on two days old just started turning itself off after 30 seconds. Cannot get it to stay on.
  • jakemckinney Jan 21, 2009
    Mine is two days old, too, and it also keeps turning off.
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
SOURCE: Sharp Aquos 30" monitor only
The monitor will not work without the AVC box.
Do you still have the monitor? Is it in good condition? Would you be willing to sell it? If so, please email me at info@btwconcepts.com
Posted on Jun 10, 2011
MNfisherman
  • 11896 Answers
SOURCE: sharp aquos 46 picture disappears intermittently
it might mean there is an intermittent connection or cold solder joint somewhere inside the set.
But I wouldn't just settle on that.
Here are some other things to check:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Here is what I suggest:
ONE: Give it a hard reset. Possibly the software codes in the power management are corrupted. Just unplug the tv line cord for 4 hours. That will reset everything internally to factory defaults.
TWO: Give it the old whacking test. Just bang on the cabinet in many places with your hand or fist. That will restart any cold solder joints or loose connections.
THREE: If the above procedure does not help, then you will have to call in an expert tv tech; OR just live with it and put in a line cord switch so that when it is OFF, it is really OFF.
Posted on Jan 17, 2009
caroldon
  • 17130 Answers
SOURCE: my sharp aquos lc52d65u dosent
It is possible that there is a failure of some components in the main board or a possible break of connectivity. You must be familiar to open the set and have some basic knowledge of the electronics inside. Use a good source of light to check for physical indications of burnt out, dry solder joints or connections.If after soldering there is no result then you will have to take a voltage check and see for any short in the main output drive, short in the capacitors. Take your time to make a good check for open circuits as the feedback is required for the smps to power on. Hope you get this right. Good day
Posted on Aug 02, 2010
walesarumi
  • 6993 Answers
SOURCE: Sharp Aquos television model number
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
This is a common problem faced by many other users too. To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
You can buy these part at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Regards.
Posted on Aug 13, 2011
Why is my 2011 Sharp Aquos TV crashing?
Sharp Aquos "crashing" - HDTV - Streaming Video & TVs - Tom's Guide
www.tomsguide.com/forum/24705-4-sharp-aquos-crashing
Aug 11, 2005 - 7 posts - ‎1 author Archived from groups: alt.tv.tech.hdtv (More info?) I have a Sharp Aquos 37" LCD TV(37GD6U). Every now and then I can turn it on,
Oct 20, 2015 | Sharp Televison & Video
Our Sharp GA864WJSA TV intermittently turns itself off for a few seconds, then turns itself on again. Please help???
Sharp Aquos problem - YouTube
? 1:41
www.youtube.com/watch?v=-EuJZ9NUf3Y
Apr 24, 2012 - Uploaded by rsimon24
So my tv is just turning off by itself, some people tell that is a software issue, others resistance hardware. Has .
Sep 12, 2015 | Sharp Aquos Televison & Video
I have a 52 inch sharp aquos the screen is broken can I replace it
It will be expensive and time consuming, but it can be done. There are many web sites that sell replacement screens. Just google TV replacement screens. You should download the service manual for your TV from Sharp's website before attempting to do the repair.
Oct 14, 2012 | Sharp LC52D65U Aquos 52 inch 1080p LCD...
52 sharp aquos tv wont turn on. Hear click of tv
This tends to be the result of an electrolytic capacitor somewhere, either on the main board or the power supply board bursting due to overheating. In this case you can pull off the back paneling and review the boards over to make sure all the capacitors are in excellent condition. After identifying a bad capacitor you can buy one from an electronics store in the area or a reputable online source. To replace it this will require soldering. Look for a capacitor with the same uF, the voltage can be the same or higher. Make sure all the power is out of the system before servicing, also make sure to note capacitor polarity observing the negative indicator line on the side. If your not sure this can be done at home I would recommend taking it in to a servicing shop. If you do not know what a capacitor looks like do a google image seatch for both examples of a good and bad copacitor. I honestly hope it's something much simpler, I hope this helped and good luck.
Mar 03, 2010 | Sharp LC52D65U 52 in. LCD TV
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HAVE A SHARP 52" LCD #LC52D65U AND I CAN'T FIGURE OUT HOW TO REMOVE THE STAND SO I CAN MOUNT IT ON MY WALL. PLEASE HELP ME
On the back of your TV, there are 4 long hex bolts. It should have triangles pointing towards the holes. Take the 4 long hex bolts out and the stand itself should slide out with no problems.
May 21, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Sharp aquos lines threw the picture
I've seen this problem before and if caught early (usually only a few pixels), its fixable. But if it has already started forming a "line" it might be too late and you might have a defective LCD panel. Most of the time, doing the factory initialization helps with this problem.
(WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
1,144 people viewed this question
Top Televison & Video Experts
