Question about GE WWSE5200B Top Load Washer
Lid switch, waterpump good. tub ill noy spin. GE washer WBSE3120B2WW
docjohn174
  • 943 Answers
SOURCE: GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Posted on Sep 11, 2008
tbirdfan1
  • 3051 Answers
SOURCE: ge washer wbse3120b2ww does not fill water and go to the final sp
hELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Posted on Jul 31, 2009
dmftrucker
  • 1922 Answers
SOURCE: My GE washer won't spin or agitate
check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
Posted on Aug 24, 2009
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Posted on Jan 16, 2010
oldmanewtoys
  • 414 Answers
SOURCE: I have a GE WBSE3120B2WW top loading washer and it
wig wag relay needs replaced
Posted on Mar 08, 2010
I have a GE Top Load washer model # EWA 5600G. The washer idiot light indicates the washer is in the wash mode, however nothing is happening, tub is full of water, but no adigation....motor is not...
Hello, welcome to FixYa.
I understand based on your post you have a GE topload washer, model EWA5600G, correct ?
The most common problem which manifest in the manner you've described is the lid switch. I don't know what you've done aside from what you mentioned, "Tub spins freely, belt is on, motor is not running." but I'd suggest checking the switch.
The motor should only come on in the spin cycle if no water is present...if it is indeed full of water and ready to cycle then it will come on as well.
If you do not have motor action present at anytime no matter where the cycle is, I'd be suspicious of the lid switch. Have you tried by-passing the lid switch and testing it in spin ?
As you can see there are many possible scenario's that may prevent the motor from operating, a timer, a lid switch, a pressure switch and of course the motor itself. That's getting ahead of things though.
Let me know what results from by-passing the lid switch and perhaps that will get us moving forward again. Good luck.
Regards,
Macmarkus :)
Sep 08, 2011 | Washing Machines
Washer wont spin
hello,
The washer will not spin/rinse if it cannot drain the tub first. To start with check the drain pump for any clogs/obstructions; also check the drain hose for any blockages.
After this is done check the drain pump motor and drain pump, also check the wire harness from the CCU (central control unit) to drain pump and replace the part that has gone bad.
thanks.
Aug 29, 2010 | GE WBSR3140DW Top Load Washer
I have a GE wcx1070 and it will not agitate or spin will fill the tub and drain but won't spin. I have checked for obstrutions in the tub and under the agitater. and the belt looks good if it does spin it...
I think it might be the lid switch. 8e3407e.jpgas you can see it can fail mechanically and electrically. To get to the lid switch you remove the front panel firstf373b4d.jpgthen you can remove the top and access the slid switch.
Use this training manual
Aug 06, 2010 | GE WVSR1060A Top Load Washer
Washer does not spin and drain
It's most likely that the lid switch which is either loose or faulty. The lid switch keeps the tub from spinning when the lid is up or the door is open -- it's a safety feature.
More info, let me know...
Charlie
Aug 21, 2009 | GE WVSR1060A Top Load Washer
Washer starts to spin and quits after 10 seconds. It is like the spin timer is set to short or something.
place a screwdriver into the lid switch hole when the lid is up, timer on spin be careful as the tub will probably start to spin
if it does check lid switch and, lid for a broken lid pin that goes in the lid switch hole
Jun 08, 2009 | GE WBSR3140DW Top Load Washer
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
GE WWSE5200B Top Load Washer Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
