Question about DSC Wls914-433 Wireless Pir Motion Detector Pet Immune
Attempting to change the batteries in my WLS914 wireless sensor, I removed both the front and back covers. Did replace batteries. Now my Keypad has a trouble light on. States that my zone 25 (WLS914) is open.
Keypad 5130c
i expect that some of the digit in that particular cellphone is not working. if you want to clean your key pad then you need to open it. removed the battery cover, the battery, back cover, untill you see the 6 screws that holds the front cover. Removing the screw will automatically remove the front cover and will show you the key pad. if you want to check the digit which is not working then you fix the battery and holding it firmly press the power On button. assuming that you already know what digit is not working then you can proceed by removing the plastic cover of the keypad and by using pencil eraser you can clean it.. from 0 - 9....
Sep 22, 2013 | Nokia 5130 Cellular Phone
Tip
How to disassemble a nokia n95
First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.<br />Now move the slider up and remove the two screws at the top of the phone.<br />Run your fingernail along the edge of the join of the front cover to unclip it.<br />You should now have the front cover removed. The keypad should be loose as well.<br />Flip the keypad part back to access the ribbon which connects the LCD to the phone.<br />To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.<br />Pull the LCD in the direction like you are sliding the screen up.<br />You can now replace the screen.<br />Reverse the whole procedure for reassembly.
on Jan 10, 2011 | Nokia N95 Cellular Phone
Inputing the code into the wireless keypad does not operate the garrage door.I think the battery may haved failed.I see an acess cover at the bottom of the key psd ,but Iam unable to remove it.What...
Usually the cover for the battery access slides down to remove. No model number doesn't help as there are several. If it still doesn't work after battery replacement and your other remote units do work it is not the receiver that is bad it is the keypad.
Feb 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Lcd screen disconnected?
to get to the screen of your phone, follow the process below:
Pull the LCD in the direction shown.
Take care
Oct 12, 2010 | Nokia N95 Cellular Phone
How do I change the battery on a chamberlain keypad for a garage opener
There is a small phillips head screw near the bottom on the front of the keypad. Remove this and then the small cover.
May 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener (liftmaster 1265) buzzes when attempting to open or close the door but the chain doesn't move
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dsc sensor not operating properly. I want to change it, is this very difficult? Thank you.
You don't mention what type of sensor. I assume it is a motion detector. Before replacing I would strongly suggest you first remove all power from the system by disconnecting the backup battery inside the control panel then pull the system's power transformer which should be plugged into an electrical outlet nearby. You will know that all power is removed by looking at the keypad - all lights on the display are off. Next remove the motion detector's front cover. Some detectors have a small screw on the bottom so that when removed the cover pops off. Others need to be opened using a flat blade screwdriver and prying off the cover. Once the cover is removed there should be a 4 conductor wire that is wired to a series of terminals. Observe the polarity of the wires, disconnect them and remove wall mounting screws. Install new unit. Be sure when wiring to connect power wires correctly. The 4 conductor wire should have a red (positive) wire and a black (negative) one. Connect the red to the + or pos terminal and the black to the - or neg terminal. Read the instructions that came with the new unit if in doubt. When finished plug the power transfomer back in then reconnect the battery (in this order). If power is connected properly the motion detector's red walk test light (indicating motion) should light whenever you walk in the protected area. Also make sure the system recognizes motion by first closing all protected areas such as windows and doors to get a system ready or green light indication on your keyad, then walk around the protected area. A properly working detector will show you a fault on the keypad everytime the system senses motion.
Sep 11, 2009 | DSC Home Security
How do I change the keypad on the Nokia 6220 classic ? Thanks
remove the back cover .. then remove the front cover. it will bw really tight check for the points from where it is inserted into the body.. whn u get the front coer out. take out the key pad and replace it
Aug 14, 2009 | Cell Phones
Garage keypad (liftmaster security)
NOT SURE WHICH UNIT YOU HAVE - MOST OF THEM HAVE A SMALL PHILLIPS SCREW NEAR THE FRONT BOTTOM THE BATTERY IS UNDER THAT SMALL COVER.
Mar 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
HELP!!!
Replace keypad is easy.
Remove the metallicsticker on the front to expose 2 screws, remove these, remove the two rubber stopper at the top on the back to expose two screws, remove them.
Take the battery cover off and unclip front. Keypad falls out of front housing.
Replace and reverse procedure.
Jun 24, 2008 | Sony Ericsson Walkman® W880i Cellular...
DSC Wls914-433 Wireless Pir Motion Detector Pet Immune Logo
Top DSC Home Security Experts
yobo007
yobo007
Jerry Kramer
Jerry Kramer
Terry Weaver
Terry Weaver
Are you a DSC Home Security Expert? Answer questions, earn points and help others
