Question about Texas Instruments TI-30XA Calculator
How do I raise e to a fraction - Texas Instruments TI-30XA Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Evaluate the fraction first or, equivalently, put the fraction inside parentheses. For example, to raise e to 1/2 press:
1 / 2 = 2nd [e^x]
or
( 1 / 2 ) 2nd [e^x]
Posted on Dec 01, 2012
  • kakima Dec 01, 2012
    1 / 2 = 2nd [e^x]
    or
    ( 1 / 2 ) 2nd [e^x]
How to raise a fraction to the 45th power on the TI-30XA calculator
Enclose the fraction ib parentheses then raise the whole bracket to the power (a/b)^45
Feb 12, 2014 | Texas Instruments BA-II Plus Calculator
How to put negative fractional power to BA11 plus calculator or how to solve with formula.
Put the fraction inside parentheses so the division occurs before the power, and use the +/- key instead of the - key to enter a negative number. For example, to calculate 8 raised to the minus one-third, press 8 y^x ( 1 +/- 3 ) =. You should get 0.50.
Oct 14, 2013 | Texas Instruments BA-II Plus Calculator
How do I compute fractional exponents on the TI BA II Plus calculator?
The same way you raise a number to a non-fractional power, using the y^x button. For your example, press
3 y^x ( 1 / 1 2 ) =
or
3 y^x 1 2 1/x =
Dec 08, 2012 | Texas Instruments BA-II Plus Calculator
How do i raise an a number by a fraction exponent
Use the 'y^x' key in the upper right corner. Enter the number, then [y^x], then the exponent.
Mar 30, 2011 | Texas Instruments TI-30XA Calculator
How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
Jan 13, 2011 | Sharp EL-501WBBL Calculator
How do you rasie a number to the power of a fraction
This depends on the calculator, but there should be a key marked either x^y or y^x to raise one number to a power. If the power is an expression (such as a fraction), use the parentheses keys to delimit the expression.
May 21, 2010 | Office Equipment & Supplies
I am trying to get the calculator in "basic math" mode. displaying the answers in "basic form" unless i am selecting otherwise.
The calculator has two Input/Output modes: MthIO and LineIO. Since I do not know exactly what you mean by "basic math" mode or "basic form" I must summarize some properties of each mode so that you can recognize your "basic math" mode.
  1. In MthIO, you have access to the multistory templates to enter fractions with a horizontal fraction bar etc. the exponents for the powers are raised above the main line, etc.
  2. In LineIO, what you enter in calculator is all on the same line, fraction and radical results are displayed as decimal numbers, etc.
The calculator is by default in the MathIO mode. If it not, you can restore it by pressing the key sequence: [SHIFT][MODE] (SETUP) and select [1:MthIO].
To set the LineIO as the default, you press the key sequence: [SHIFT][MODE] (SETUP) and select [2:LineIO].
Hope it helps.
Thank you for rating the solution.
Dec 14, 2009 | Casio FX-115ES Scientific Calculator
How do I raise a number to a power other than 2?
You have the [X to the 3] for the cube and the [Y to the x] for any exponent: (positive, negative, or a fraction).
Hope it helps.
Sep 28, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
66 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
