Question about Frigidaire FEQ1442ES Electric Dryer
My Frigidaire dryer model # FEQ1442ES, it got 5 led on the far right and 4 of the lights blink 9 times and the start light flashes for 5 times,so i'm reading it as 95 but i haven't saw a 95 co
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
E95 is for a bad thermister. Here is the part to order.
Posted on Dec 01, 2012
4 Suggested Answers
SOURCE: Frigidaire FEQ1442ES dryer beeping three times and
I have the same problem with the same dryer, but don't know why either. I was reading on one posting that a button might be stuck so the dryer thinks the button is constantly being pressed.
Posted on Jan 25, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Frigidaire FEQ1442ES Electric Dryer not producing
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Posted on Oct 10, 2010
TheMobilian
  • 8220 Answers
SOURCE: frigidaire dryer GLEQ2152ES0...dryer starts for a
Could be a loose connection at the receptacle . The PF is power failure. Check your terminal connections.
Posted on Nov 14, 2011
Dryer will not start
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
WHY IS DRYER TURNING OFF AND 4 LIGHTS ON PANEL FLASH
Good Morning Friend,
I understand your Frigidaire dryer, model# FEQ1442ES, runs for about 10 minutes then turns off. I also see, that when it turns off, all the lights on the front panel are flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer Beeping
Woah? Crazy machine you got there. You should try unplugging it or reseting it, if that doesn't work, contact ur nearest washing mashine place or fix place.
Dec 16, 2013 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ1442ES dryer beeping three times and flashing lights. How do I stop it. Have removed and cleaned lint screen and the cage.
Jan 16, 2010 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
732 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
