Question about Westinghouse Washing Machines
Capacity of white westinghouse washer model# mwx233rbw3
5 Suggested Answers
SOURCE: White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Posted on Nov 27, 2008
  • 36 Answers
SOURCE: clogged screen for White Westinghouse washer
the screen is located inside the water valve. you will need to take the hose of of the valve and take a small flat screw driver and pull the screen out
Posted on Jan 03, 2009
  • 57 Answers
SOURCE: Excessive vibration since moving--not before
is the place you moved the washing machine level are the legs level if so you have a blocked sump
Posted on Jun 24, 2009
  • 6277 Answers
SOURCE: how do u replace broken
If yours is a 'standard' front loader (you do not say the actual model number) the belt should be easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 15, 2011
White westinghouse 8cycle washer will not spin or drain now it wont do anything model number WW5833ES1 i thought it might have been circuit related so i reset the fuse box and removed the clothes from the...
does it fill with water yet?if so then its the lid safety switch that gone bad under the top lid,this will kill all cycles other than fill,if it doesn't fill with water either then the timers defective
Jan 01, 2011 | Westinghouse WWS833ES Super Capacity Top...
I just replaced the belt on my White WESTINGHOUSE la 560axw2 WASHER. It is now severely out of balance whenever it reaches the spin cycle.
The problem may be with the top springs may be damaged you can replace the spring set completely to get the smooth running in the spin
Dec 30, 2009 | Westinghouse WWS833ES Super Capacity Top...
Jun 24, 2009 | Washing Machines
LOUD HUM NOISE
check bearings or shock absorber.
Feb 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Clogged screen for White Westinghouse washer
My white westinghouse top loading washer wont open, the lid stays locked
Lid lock mechanism is bad and needs to be replaced. To unlock lid take off front and you'll see what to do. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Westinghouse WWS833ES Super Capacity Top...
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
32 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Harjeet Singh
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
