Question about Ovens
Modern Maid Flinders Natural Gas 54cm Upright Gas Stove
  • 833 Answers
SOURCE: how do you clean an
Generally, there is a latch which closes the door on some units...on others it is electrically actuated.  Turn the controls to clean.  Generally, there is a function control and a temperature control which must be activated.  This will latch the door electrically.  A two hour cycle is about right for most soil, if you're given a choice.  Ventilate the area...it smells!  The door will unlatch about half an hour or more after the cleaning stops.
Posted on Nov 26, 2008
SOURCE: Modern Maid Wall Oven DGO757 ignitor gets
I have a Modern Maid Wall Oven and the pilot light waant stay lit. What's the best solution?
Posted on Jul 20, 2010
emissionwiz
  • 80339 Answers
SOURCE: Modern Maid model QKU-739 Gas Town House Range and
Hello
Well this is very simple, if the oven won't go on it is not an input problem from you if you set the temperature it goes on automatically, so if it won't light you most likely will need to have the oven tested, it is very likely that one of the following has failed, the Gas Valve or Gas Valve closing coil, the Electronic Igniter (lights the gas burner) or the the Flame sensor, to test these requires a service technician or a high degree of skill of testing procedures for electronic components.
Posted on Nov 25, 2010
SOURCE: natural gas to LPG conversion kit for old new world gas stove
Silver solder up all burner jets and redrill to .6 mm then reset adjusters so you get a nice blue flame with small orange tips.and oven burner to .8mm i have just done a new world 75 last week.Works perfect
Posted on Jan 29, 2011
Daniel S
  • 4323 Answers
SOURCE: How do I remove the
Hi
Please click on this link to follow the step by step instructions that will help you in removing the door. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 19, 2011
I have a modern maid double wall oven (gas). I set it to clean last night (at 3:00AM). It is now 12:PM the next day and it can't unlock it. What should I do?
Try turning the main power off to the house for 5 mins and turn it back on see if that reset your oven.
Jan 01, 2015 | Ovens
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I was baking and steam was coming out of the stove area right below the knobs? what do I do about that? is it broken or is there a setting I can change?
Steam is a natural product of baking but the heat from an oven rising directly to the control knobs on any cooker is unacceptable. Those knobs are not decorative mouldings to make the appliance look pretty, they are a means of controlling the gas valves! I suggest you check that your appliance is standing square upright and level. If it is then I think perhaps you might replace the oven door seal.
Sep 19, 2011 | Tappan 30IN ELEC IGNa Oven
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
Modern Maid Wall Oven DGO757 ignitor gets orange,but does not fire oven.
HI, there are gas valve coils that initiate the opening and closing of the gas valves. these coils will become unstable overtime. if the coils are malfunctioning, it will cause the symptoms you are experiencing with your oven at this time. i recommend replacing the failing gas valve coils asap if possible.
It should be two or maybe three coils that are attached to the valve assembly(burner assembly). they are black and, cylindrical in design. replace these coils.
Jun 10, 2009 | Ovens
Natural gas to LPG conversion kit for old new world gas stove
Apr 14, 2009 | Ovens
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Ovens
Change gas oven from natural gas to propane.
Hello littelhauler,
Most Oven manufacturers offer a conversion kit for this changeover.. I would contact a local applicance repair shop near you and tell them what you are trying to do as well as provide them with the brand and model of your stove.. They may have or be able to order a conversion kit for you..
Regards,
Rick
Dec 13, 2008 | Ovens
How to check to see if gas stove has been converted to propane
The only thing you can do is look for a little (usually gold) nozzle connected to the orfice
propane burns blue and natural gas has the yellow tint to it
May 01, 2008 | Ovens
Ovens Logo
78 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
