Treo 775P continuously cycles from the Orange Palm logo to Access Powered.
5 Suggested Answers
  • 7 Answers
SOURCE: Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Posted on Apr 11, 2009
SOURCE: Treo 700p locks on Access Powered
I called Sprint tech support. With the battery in, hold the red power button down until the screen comes on that asks you if you're sure you want to reset your Treo (you will lose all information but hopefully you're like me and synch it frequently with your desktop.) I reset it and then synched it with my desktop and got almost all my info back - just had to redo email passwords and some settings. It was easy.
Posted on Sep 30, 2008
Joed911
  • 4338 Answers
SOURCE: my palm treo 755p power cycles to the access powered screen
There are different types of resets that may cure this issue. Try them, starting from a soft reset.
http://forum.brighthand.com/showthread.php?t=13189
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 26, 2009
  • 47 Answers
SOURCE: My Palm Treo 700p is in a loop....Access Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, Hard Reset.
Posted on Feb 20, 2010
After a hard reset (reinstall battery while holding down the end key) I receive the ACCESS Powered screen. When I let the end key go I receive the prompt to delete all data. I key the up arrow and the...
Hi there if you can access the manufacturer website you should download the software available for your device, this should solve the problem.Simply go to the website and look for your model of palm and follow the steps.
Jul 06, 2010 | Palm Treo 755p Smartphone
"access powered" after the "palm screen"...keeps doing the same thing over and over
you have to hardreset your phone it will wipeout your all the data. but it will work
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p is hard reset.
Jun 22, 2010 | Palm Treo 755p Smartphone
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
Freezes up on palm logo
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your Treo, so only do it if you have to. Google how to do it, and it's reset.
Feb 20, 2010 | Palm Treo 750 Smartphone
My Palm Treo 700p is in a loop....Access Powered screen for 8 seconds, Palm logo for 1 second during which the keyboard lights up, and then blank screen for 1 second...then it repeats continuously. Any...
Feb 15, 2010 | Palm Treo 700p Smartphone
Palm 755p Malfunction
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your Treo, so only do it if you have to. Google how to and it will work perfect.
Feb 06, 2010 | Palm Treo 755p Smartphone
My palm treo 755p power cycles to the access powered screen
Thanks, Joe
May 26, 2009 | Palm Treo 755p Smartphone
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
Sep 29, 2008 | Palm Treo 700p Smartphone
Problem
This happened to me after I installed an update and Sprint told me it could not be fixed. They replaced my 755 with a new one.
Dec 11, 2007 | Palm Treo 755p Smartphone
Computers & Internet Logo
David Payne
David Payne
