Question about Shuttle XPC Computers & Internet
Quick ? for U, I have a SHUTTLE and I am Trying to put the OS onto it but it wont complete the whole process....have u heard in order to download XP or newer u must use a floppy disk to download OS on to A shuttle barebone systerm? If so how do I transfer win XP to A floppy and proceed to download win onto the harddrive
  • 3,799 Answers
You would need about 1000 floppies to store Windows XP. You need to go into the BIOS and select the primary boot drive to optical(cd). Then restart with the windows disc in the CD drive. Floppies haven't been needed to install the OS since Windows 98.
Posted on Apr 15, 2013
sandrew
  • 2961 Answers
SOURCE: my shuttle wont boot
If it's a new build, can you give details on processor etc. But if there is no bios, it's normally a memory incompatability problem, or the processor isn't active.
Posted on Jan 08, 2007
leecom72
  • 4806 Answers
SOURCE: ez661-t cd
I wouldn't bother with windows 98, its more bother than its worth! XP has been given an extention to 2013 so you should be able to obtain a copy at a microsoft certifed retailer, when you update windows the drivers should be installed automaticly
Posted on Nov 13, 2008
zabrinaliang
  • 15 Answers
SOURCE: I have a Shuttle SS56 XPC KTS24.5G1e at X5 misssing.
Check with your local computer store.
Posted on Dec 08, 2009
zabrinaliang
  • 15 Answers
SOURCE: Shuttle SP35P2 Pro barebone system doesn't identify a SSD drive
If the SSD card is designed for a Dell, then this card is a proprietary card that only works with Dell.
SOURCE: Is there a sound driver for windows xp pro as the
Usually, you get the drivers for XP, Vista, etc. The XP version should be fine enough for you. If you are not able to get your audio even after installing the driver, then the issue could be something else. If you are able to see the speaker ICON on your task-bar, then this means that the sound is enabled.
Posted on Mar 19, 2010
Bobbin wont lock into place
Hello Lisa, There is a lever on the bobbin case that is spring loaded that secures the bobbin case to the shuttle or rotary hook, whichever you have. If you have the bobbin case in the correct position and the bobbin case pushes completely onto the stem of the shuttle but does not latch onto the stem to hold it in place, you may need a new bobbin case.
Mar 02, 2014 | Euro-Pro Sewing Machines
What's your problem?NEED HELP PUTTING WINDOWS XP HOME EDITION
It sounds as if you have a failed or failing hard drive. Replace the HDD and then go for a re-install.
Nov 05, 2012 | Shuttle Computers & Internet
Shuttle computer will not finish boot up process
This is usually because the operating system is corrupt. Try to start the computer with the OS disk in the drive. This may work, if it doesn't I would suggest getting a new copy of the OS.
Jun 24, 2012 | Shuttle Computer Shuttle Xpc X27d-bk-v1...
I need shuttle mv43v motherboard audio driver
Hi, you can download all the drivers from here:
http://global.shuttle.com/products/productsDownload?productId=588&osId=5&panelId=2
But there is only drivers for Windows 2000,Windows 98 / WinME
The file needs to be unziped before installation.
Hope this will help you.
Aug 20, 2011 | Shuttle MV43N Motherboard
Help me in formatting my hard disk
Put OS disk in shut off computer
restart computer
push ENTER to boot from cd- this is not happening.
It is possible that your OS disk isn't good
Apr 12, 2010 | Dell Dimension 2400 PC Desktop
How to completely clean /delete/and thn reboot
What do you mean clean, delete and reboot? Are you trying to re-format the whole hard drive? If yes then follow this. 1. Prepare the Windows OS disc. 2. Use ac adapter on laptop. 3. Power on laptop then immediately keep tapping on F12. 4. Boot menu will appear use then the arrow keys highlight on onboard CD/DVD-ROM then insert the windows OS disc then press the enter key. Just wait until it loaded the windows setup. Just follow the prompt on the screen on deleting the partition. Windows has its instructions during the process.
Mar 31, 2010 | Dell INSPIRON 6000 CENTRINO...
HOW TO INSTALL XP IN VISTA OS OF LAPTOP HP PAVILIION
Hi there.
The only way you can install XP on a Vista machine is to install "virtual XP" onto Vista using Virtual PC 2007.
Here is a site that will take you through the procedure step-by-step and gives links to download Virtual PC and install it onto the machine.
Please be aware that some drivers may not work whilst using XP when you have it installed.
http://lifehacker.com/software/windows/geek-to-live--run-windows-xp-inside-vista-with-virtual-pc-238071.php
Have fun, good luck and thanks for using FixYa!!
Mar 23, 2009 | HP Pavilion DV6700T Notebook
Unable to install CD
what os were you using....quick note...vista has too mant bugs not the best os...xp is..
Aug 30, 2008 | Computers & Internet
Trying to copy a dvd
HEY PUT A DISC TO COPY THEN SELECT COPY DVD OPTION  AND SELECT NEXT  DESELECT THE QUICK COPY NOTCH
AND THEN CLICK NEXT MAKE SURE YOU HAVE ENOUHGH DISK SPACE WHWEN THIS PROCESS COMPLETES  IT WILL ASK FOR THGE BLANK DVD INSERT THE DISK AND WAIT
DON T CLICK ANY THING WHEN THE CD EJECTS
IT FINISH BY ITSELF
Dec 31, 2007 | Lite On LH-20A1P (0844149002088) Burner
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
Computers & Internet Logo
129 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
