Question about E-Machines emachines (emachinees) CD-ROM Drive
Code 19 on e-machine cd rom
Cd rom will not run. Driver refuses to update on model t5234
  • E-Machines Master
  • 27,725 Answers
Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button. Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option. Click "Yes" to confirm the deletion. Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again.
Click "Yes" to confirm the deletion. Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error. Hope this helps.
Posted on Dec 10, 2012
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: my e machine EL1850
if you are having problems with your cd/rom
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor:
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Posted on Jul 07, 2011
bronk50
  • 27725 Answers
SOURCE: cd rom driver wont update
there should be a small hole on the front panel of your cd/dvd press a straightened paper clip into the hole until you feel it press something in this should open you cd/dvd if not
click start Control panel administrative tools computer management device manager scroll to cd/dvd rom drives + to expand could be a yellow question or exclamation mark ? ! or a red X right click update drivers
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
to check the registry
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. If your computer came with a motherboard disk the drivers could be on it
hope this helps you
Posted on Apr 16, 2012
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
My e machine EL1850 cannot find the cd rom drive. I cannot run any cd's. do I need to download a driver? which one?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jul 06, 2011 | E-Machines emachines (emachinees) CD-ROM...
WHEN I TRY TO INSERT A CD, IT REFUSED WITH HEARING OF ROTATION SOUND, WHY?
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Jan 07, 2011 | Computers & Internet
My cd-rom drive isnt working.. this message is displayed in device manager.. Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged....
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 05, 2010 | Gateway (5500652) (  5500652)...
Cd drive wont open
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
hope this helps
Nov 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
Why is my disc drive not working? model #T3985
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
hope this helps
Nov 16, 2010 | E-Machines emachines (emachinees) CD-ROM...
I installed the DVD Rewriter but I am getting Code 19 Error (registry).
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Oct 31, 2010 | LG Computers & Internet
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
My cd/dvd rom has stopped working it says that the driver is ok but there is a (code 19) stopping it working any help gladly recieved many thanks
Please roll back your driver or you need to reinstall driver from driver CD i think this is helpful to you if this solution is not solve your problem then plug out your CD ROM and replug CD ROM properly
Oct 04, 2009 | Computers & Internet
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
