Question about Sony Audio Players & Recorders
Carousel does not turnsony 60 cd changer hcd-mg110
    New Friend:
Hi Yam_man_dan, I have the same problem with my stereo. How do I check the gears? Do I remove the rotator that holds the CDs?
Posted on Aug 15, 2013
4 Suggested Answers
RFICKES
  • 51 Answers
SOURCE: Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
Find the screws that hold the to of the case to the chassis. They should be on the bottom, and back. Once they're removed, gently pull the top off. You may have to fish under the carousel to get the CD, but if you're gentle, you should be okay. Make DARN sure the power's unplugged, and keep your tools away from the power supply, just in case there's some residual energy left. Good luck!
Posted on Jan 04, 2009
  • 382 Answers
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Posted on Jan 29, 2010
  • 17 Answers
SOURCE: My Pioneer PD - F1007
if you email me yam_man_dan@yahoo.com (put pioneer pdf in title) will sed you service manual with realignment instructions plus disassembley instructions regards yammandan
Posted on Aug 19, 2010
If anybody can help me please I need to know how to repair the carousel before the CD changer he does not spin thank you
Most of the carousels are driven by a small motor through a gear train, but some are belt driven. You would have to look underneath the carousel to determine what the mechanism is. If it's belt driven, make sure the belt isn't slipping. With the changer unplugged, find the carousel motor, then gently turn it by hand (make sure you are turning it in the correct direction) to check for excess friction, broken gears, jamming by a foreign object, or slipping. If you hit a hard stop while turning the motor DO NOT FORCE IT. Investigate the stop; it's probably your problem. Some changers rotate the motor in one direction to turn the carousel and in the other direction to clamp the CD in the spindle mechanism. If the spindle clamp is hung up, this will prevent the carousel from turning.
Jun 16, 2015 | Audio Players & Recorders
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Sony 60 cd player model #mhcd-mg110 doesnot function properly
Try posting it in the CD section, not the Minidisc section.
Dec 01, 2012 | Audio Players & Recorders
My Pioneer PD - F1007 301 Giga Changer is jammed and the CD carousel will not rotate.
Aug 19, 2010 | Pioneer PD-F1007 301-Disc CD Changer
How do I clean a 5 CD disc changer?
i think the concept of this type of machine is one actual disc reader (the eye needing the cleaning) and a carousel that carries discs to the play position. So a cd lens cleaner can be placed in any of the carousel parts and do as much good as in another, once should be enough.
Jan 31, 2010 | Panasonic SCAK410 5-Disc CD Changer
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
Sony Mini Hi-Fi MHC-MG110 no longer chooses CDs at random
Unplug the power for a while and load all CDs. It could solve the playing old paylist.
Jan 10, 2009 | Sony MHC-MG110 CD Shelf System
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
207 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
