Question about Dell Inspiron 9300 Notebook
PC wont boot to windows xp
IDE Disk S/N NN15T4B154G9
0FOO:0244
MSG BLOCK 36229138
UNCORRECTOBLE DATA ERROR OR MEDIA
ERROR 1000-0142 UNIT 4 DRIVE
SELF TEST FAILED
STATUS BYTE=79
    Problem Solver:
  • 13 Answers
This seems to Be a common problem with dells, The only way to fix it is to buy a new HD, And all data is Unrecoverable. Sorry for your loss
Posted on Jan 11, 2009
IDE disk read test block failure
try to run with chkdsk command and if it is fail kindly replace the disk.
Nov 14, 2011 | Dell Dimension 4600 PC Desktop
I have a Dell Inspirion 8600. XP SP3 w/all of the latest MS updates. Got keyboard error message, rebooted and got blue screen related to keyboard error. rebooted, reset Boot menu to Dell factory default....
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 04, 2011 | Western Digital Computers & Internet
Latitude D510 Hard Drive S/N IDE 167K0396T error. The laptop will not boot. Error test found only 1 location. Read Test error 0f00:0244 at Block 5842740. Can Windows XP be repaired so the computer will...
If boot sector of this hard drive resides on block 5842740 then this is a problem. Try followings...
1. Boot with a XP CD, try to repair. OR
2. When PC boots are you able to go to safe mode by pressing F8? If yes, try Good Known Configuration option first.
3. Otherwise boot in safe mode, go to command prompt, type chkdsk and then reboot your PC and let it check disk. If it ask to find sector and block issues and wanted to gic them automatically, accept it.
Good luck....
Jamil
Oct 05, 2009 | Dell Latitude D510 Notebook
Error code 0244
Hi there.
Error Code 0F00:0244
"Msg Block 5*****4: Uncorrectable data error code or media is write protected"
Sorry to say the hard drive has failed or is corrupt with bad sectors, with these Dell drives there is no way of fixing them.
There maybe a possibility that you can recover your data if it still spins up and you add it to another computer as a slave device.
Good luck and thanks for using FixYa!!
May 20, 2009 | Dell Computers & Internet
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Error Code: 1000-0146
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Dell Inspiron 9300 Notebook Logo
624 people viewed this question
Alun Cox
