Question about Toshiba 24HV10 24 REGZA Full Multi System HD LCD TV
I was connecting my DVD player to my 24hv10e. The tv was working fine but i connected one of the jacks to the "service use (only)" jack and the tv went blank and silent. Can't get it to turn on no
  • 192 Answers
SOURCE: HDMI Input Failed
I've been seeing alot of this out in the field. The cable is thick and heavy, after awhile the HDMI connectiion inside the set comes apart and breaks from the main board. In my opinion the only difference between Component jacks and HDMI inputs is the thought of reducing the amount of wire mass in the back of the unit. It's more pleasing to the eye. If it's under any kind of warranty, call a servicer. The main PCB will need to be replaced. If it's not under warranty, use component input cables, you'll get the same performance from your set and save a few bucks.
Posted on Dec 25, 2006
harvester3
  • 181 Answers
SOURCE: Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Posted on Feb 09, 2008
  • 3 Answers
SOURCE: No Picture or audio...NOTHING!!!!
You must use the remote to toggle the player OUT of HDMI output mode to use the s-video output. The device displays black screen by default, so not possible to see the menu if using s-video. The manual states to press the 'Progressive' button to change modes. Unfortunately, you can't see what mode you're toggling through until you hit the right one (Toshiba blew it here!!). Power on the device WITHOUT a disk in (you can't change modes during DVD playback mode). There are four output modes, so press the 'Progressive' button on the remote and wait for 3 to 5 seconds for the player to switch output modes. Repeat this up to four times to cycle through the available modes. During one of the modes, you should see output to your screen through the cable hookup you've physically attached. You will also notice the led's on the front panel go on and off during the process at times. Good luck ~ and don't bother calling Toshiba support ... friggin waste of time talking to a recording that's dumber than Sh#@!!
Posted on Jul 18, 2009
budmrtn
  • 11361 Answers
SOURCE: Is there any way to
You can try using the audio line out in the back, but you may need to use and adapter if the Sennheiser does not use RCA style for audio input. Post back what kind of audio input jacks the Sennheiser uses.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 30, 2010
gopakumarg43
  • 75169 Answers
SOURCE: can you connect an aux audio jack to this tv to
Hello
Surely you can connect an external audio system to this tV. Connection should be taken from the TVs FIXED AUDIO OUT sockets at the back of your TV, with RCA cables,and can connect it to the respective sockets in the audio amp. OK.
Posted on Feb 02, 2011
Connect DVD player to TV red white and yellow wires
1. Connect the audio cables to the AUDIO OUT L (left - white) and R (right - red) jacks on the back of
your DVD Player, and to the corresponding Audio Input jacks on your TV.
2. Connect the video cable.
• Basic video connection
- Connect the video cable (yellow) to the VIDEO OUT jack on the back of
your DVD Player, and to the Video Input jack on your TV.
OR
S-Video
(optional) - If your TV has an S-Video Input jack, connect the S-Video cable to the
S-VIDEO OUT jack on the back of your DVD Player and to the S-Video jack on your TV. If your
TV doesn't have S-Video, use the basic video connection listed above.
Mar 18, 2014 | RCA RC5240P DVD Player
I plug my video jack of my dvd player to a service use only plug of my toshiba power tv model number 24hv10e, the power not turn off and no display and anything on it just a black screen and even i ca
You may need a dealer to reinstall the TV's operating software in order for it to work again. Applying an incorrect signal to the service port can corrupt necessary files on the TV.
Sep 30, 2012 | Toshiba 24HV10E 24 REGZA Multi-system PAL...
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
    Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
    Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
    If your TV has only a RF coax input, then you will need to buy an RF Modulator.
    Mar 15, 2011 | Televison & Video
    Movie has no red color only green and yellow
    Remove & re-seat the component video cables at both the TV and the DVD player.
    If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
    If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
    If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
    Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
    Connecting my DVD Player to my Digital Converter Box
    The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks.
    JUST MATCH UP THE COLORS.
    Feb 01, 2009 | Coby DVD-224 DVD Player
    How to connect up my tv with a vcr and a dvd player
    WELL DEPENDING ON WHAT KIND OF TV U HAVE,,THAT SAYS WHAT CONNECTIONS TO USE FOR BEST PIC. LIKE THE DVD PLAYER YOU WOULD, NEED A SET OF RCA JACKS,, THERE YELLOW,RED AND WHITE,,YELLOW IS VIDEO,,, KNOW IF ITS GOT ON BACK OF TV AND DVD PLAYER ,,COMPONENT JACKS ,, WHICH WILL GREEN ,BLUE,,RED,, . YOU WANT TO USE THOSE,, THAT WOULD BE YOUR BEST PICTURE. THE VCR,, ,, I KNOW MOST PEOPLE USE THAT CABLE TYPE WIRE,, WHICH WILL WORK JUST FINE . BUT AGAIN FOR BEST PIC,, USE RCA JACKS,,HOOK UP SAME AS DVD PLAYER. THANKS AND GOOD LUCK.
    Oct 05, 2008 | Televison & Video
    Jvc stereo receiver rx-5032vsl
    If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
    Dec 29, 2007 | Gateway FPD2275W LCD Monitor
    Video output not working
    it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
    Feb 25, 2007 | Kenwood DDX-6019 Car DVD Player
    Toshiba 24HV10 24 REGZA Full Multi System HD LCD TV Logo
    26 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
