Question about Panasonic PT-51HX40 51" Rear Projection Television
Picture moved over and now no picture, only circular colored lines
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
A photo posted here and verify the model number would help to know what you have.
Posted on Dec 23, 2012
How to elimate the circular moving dots during video playback?
That should just be a buffer. Give the video enough time to load from the source. Generally, there are two lines at the bottom on the playback bar, in the same space. Like, on YouTube for instance, there is the red line that shows how much you've watched, and a grey line that shows how much of the video is loaded. If not enough of the video has loaded, and the red bar catches up to the grey, it will buffer and show the circular moving dots.
Feb 04, 2013 | Computers & Internet
Bluish circular area in picture
Google the model number with "problems" since this sounds like a damaged Optical Light Engine which has been burnt/damaged by the heat from the lamp and this is a common issue on this and other Sony sets.
May 05, 2012 | Televison & Video
No picture just sound.
Ur video ic inverter board is dying about to be dead.U need a new video ic inverter board.
Aug 25, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
Mar 13, 2009 | Panasonic CT-32SL15 32" TV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Color regristration
The rings on the neck of the picture tube may have moved. this is a convergence problem and you need either a color bar generator or a very stable text screen to adjust the rings. by rotating them back and forth you will see the color outlines move. try to line all of them up until they are all on the text or image.
Apr 20, 2008 | Sony KV-27S42 27" TV
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Tye Dye Picture Always!
Is this an Analog TV with a picture tube? If so, it sounds like the screen is magnetized. Have you had any magnets (including speakers) near the screen?
Inside all analog TVs is what is called a degaussing coil. When you turn on the TV for the first time (cold), the degaussing coil is energized for a couple seconds to demagnetize the screen and then it goes off.
You can purchase an external degaussing coil and demagnetize the screen youself. A degaussing coil looks like a small hula-hoop about 6-8 inches in diameter with a AC line cord attached. I've even made these coils out of long lengths of enameled wire, electrical tape and a line cord.
Once itas plugged into the wall outlet, you hold it close to the screen (1/2' away) with the hoop facing the screen and move the hoop in a circular pattern, covering all areas of the screen and slowly move the hoop away from the screen while still moving in a circular patten until your about 2-3 feet from the screen.
If you did it right, the color splotches will be gone.
Let me know if I can be of further assistance to you or help you to locate one of these coils.
It's possible that the coil in your set is bad.
Good Luck!
- Jim
Feb 07, 2008 | Samsung DynaFlat TX-P2764 27" TV
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
