Question about Pioneer VSX-522-K 5.1-Channel 3D Ready A/V Receiver
My pioneer vsx-522-k is not working with boss acoustimass 10 series ii speakers.only the front speakers are working but other speakers are not responding.before this receivers i was using same speakers with the pioneer vsx-5000 receivers and it was working perfect
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Hi. I have just connected my Bose Acoustimass 6 series III speakers. When I run a MCACC test, the display shows 'noisy' and there is no error message. If I run it again it stops and shows just noisy after...
Either your ambient noise level is too high for the test, or you need to increase the volume for the test tones.
For any such audio calibration testing your ambient noise level should be as quiet as possible, preferably below the measurable level of an SPL meter...usually 50dB for most models.
Dec 12, 2010 | Pioneer VSX-818V-K Receiver
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
I want to add the VCS-10 center speaker to an existing bose syst
the vcs is designed to plug straight into the reciever not the acoustimass.
Jul 19, 2009 | Bose VCS-10 Center Speaker
Need wiring assistance
Just need to register, login and you can download manual from here.
It will take only two minutes.
Hope this helps.
Apr 26, 2009 | Bose Acoustimass 10 III System
Receiver for Bose AM-16 6.1 speaker
i added the vcs 10 center channel speaker for 180 to "upgrade" to the 7.1 and bought a new pioneer vsx-91txh receiver on ebay for 515.
Feb 14, 2008 | Bose Acoustimass 16 System
Pioneer VSX-522-K 5.1-Channel 3D Ready A/V Receiver Logo
277 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
