Question about Apple Mac OS X
Laptop will not turn on battery is charged - Apple Mac OS X
  • 28 Answers
Could be a dead motherboard. Could be dead processor
Or just a short. Could be a lot of things
I would call Mac support or take it in.
Posted on Dec 01, 2012
How to Save my Laptop Battery?
Charge battery fully (with laptop off) then unplug AC power. Do not continuously have power plugged in. This will ruin your battery. Remove battery when not in use for long periods. To refresh battery charge fully then run laptop till it turns off. Turn on again and wait for it to turn off. When laptop wont turn on, charge battery fully again and repeat process about 3 times. This should extend an old battery's run time.
Oct 18, 2016 | Computers & Internet
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
The battery on my c650 laptop has a charging problem
Your battery may not be securely in the laptop.
You may also need to purchase a new laptop battery.
I would go to ebay or amazon to find a decent priced laptop battery.
Aug 26, 2012 | Toshiba Computers & Internet
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
My battery is not charging. That happened after it went off when it became critical and i didn't turn in off. now the battery light has been blinking for day and when i disconnect the power cable the...
There is something wrong with your battery. you have used your laptop since it required charging. charge the battery first. and when the charging is complete then turn on your laptop . OR
connect the charger and then turn on your laptop, and continue your work and let it charge side-by side.
Oct 12, 2009 | IBM ThinkPad T23 2647 Notebook
Battery does not charge
Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
Most likely though, the replacement battery is bad.
Sep 02, 2009 | HP Compaq Evo n610c Notebook
Battery Charging Gateway MX8711
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Gateway MX8711 Notebook
Apple Mac OS X   Logo
24 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
