Question about Dometic RM2852 Refrigerator
Dometic Americana Freezer/Fridge not cooling
Returned from vacation. Breakers were off. Turned on power and everything froze incl. fridge. Days later everything thawing and now no cooling. Burner working fine. Seem to have power where needed and switches/fuss etc... ok? Suspect evaporator but no gurgling nor ammonia smell.
  • 2 more comments
  • daveqplumb Feb 10, 2009
    My parents have the same problem there is a recall on all these units see this link http://www.motorhomemagazine.com/boards/...
    they are having the same problem Dometic will only send the warranty parts for their faulty refrigerators once you have called a service technician out the repair the parts their faulty part made go bad but they won't pay for it the technician sais it will cost around $1100 to repair the refrigerator you can be a brand new refrigerator same model for 900 at PPL RV online their are lots of complaint sites about Dometic and this same problem and after is all said and done their warranty part doesn't correct the problem it is simply a precaution so when the refrigerator starts fire that the control board will shut off
  • Mathew F
    Mathew F May 11, 2010
    Does the fridge cycle off?
  • Anonymous Mar 27, 2014
    as above
    everything else seems fine except fridge not cooling
    Sniper:
  • 68 Answers
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Posted on Mar 19, 2009
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Everything freezes, model 2652 dometic americana
Hello, Inside you fridge part (not the Freezer) you will find your cooling fins,and on you fins there is a white piese of plastic and in this plastic there is a probe this will adjust you temp. by slidding it up and down.but it hasen't been touched you may have a faulty probe.acesses to plug is in rear of fridge in a black box (printed circit board)located outside of camper,you may need a qualified person to install.
Sep 14, 2011 | Dometic RM2652 Refrigerator
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a Dometic RM2601 Fridge. won't
Check around the burner area for a yellow film the ammonia has leaked out
Jun 12, 2009 | Dometic RM2620 Refrigerator
Why does my freezer work but my refrigerator doesn't?
my westinghouse fridge
the freezer is working but not the fridge
Feb 05, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Dometic RM2852 Refrigerator Logo
1,035 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
