Question about Acer Aspire 5100-5022 Notebook
Computer wont boot and i cant get to the start screen to try rec
It turns on gets to the acer screen and then pops up a window that says not enough disk space to run this app ( or close to that) it wont go to the welcome screen so i can get to programs. How can i recover it? Mt daughter hasnt had enough disk space for some time now....
  • Acer Master
  • 32,281 Answers
The computer needs maintenance periodically just like a car needs servicing. The computer generates temporary files when it is running and these consume hard disk space if they are not removed, also these files will slow down your computer.
To service your computer you should at lease once a month do a Disk Cleanup and a Defrag.
The Recycle bin should be emptied periodically.
To do a Disk Cleanup Click on My Computer, then right click on the C Drive, then click on Properties, then Disk Cleanup, then tick all the boxes to recover the hard disk space. (This process could take a few hours depending when it was last done and the size of the hard disk).
To do a Defrag, click on Programs, click on Accessories, then System Tools, then Defrag. then select the C Drive, then start the Defrag.
Again this will take a long time, you may want to start these processes overnight, don't stop them let them run till they finish. The next time you run them, it will not take as long.
Posted on Jan 11, 2009
Cant start acer 5920
Hi Dear,
Check the mention below instruction to solve you problem.
1. Is the boot sequence in BIOS set to boot from CD or DVD, if not I would suggest you to go to BIOS and change the boot sequence to boot from CD and try to boot from the CD
2. Is the computer custom built or OEM built?
3. What is the model number and who is the manufacturer of the computer?
4. Have you made any changes to the computer by installing any new software or hardware?
5. Since when are you unable to boot the computer normally?
6. You need to get Windows Vista DVD to perform further troubleshooting either to scan the computer or to perform repair install, I would suggest you to contact the computer manufacturer to obtain vista DVD.
Thanks
Sep 07, 2012 | Acer Aspire 5920-6423 Notebook
Acer Aspire 3610
How far does it get in booting. Do you see the Windows screen with the side scrolling bar before it reboots. During the boot process, start hitting the F8 key once a second until it drops you into a menu where you can select to start in Windows with safe mode. If you cant get that far, hit the DEL key a few times a soon as you boot the computer to try to go into your BIOS. If you can get into either of these, I may be able to help you.
Jan 23, 2008 | Acer Aspire 3610 Notebook
MSI N1996 motherboard with 640gig sata drive / sata DVD ROM / NVIDEA Graphics card G7500 - wont boot up windows 7 even though i install new sata drive and try new installation it wont boot up! Pre...
hi there.
this is all the info i can find.plus try the link at the bottom might help you out some more.
If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
Nov 17, 2017 | Intel Motherboard
When i turn on the computer it goes to the windows loading screen and wont go past that, ive reset it, unplugged it , and it wont go past that screen The computer is a acer E2200 desktop and it runs on...
Have you tried booting into Safe Mode? You can do this by pressing/tapping the 'F8' key after the bios screen (Acer Screen) comes up. If it does you boot correctly then, you can try to restore the system to an earlier date using System Restore. That's located in the start menu/windows orb at All Programs->Accessories->System Tools->System Restore
Feb 28, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
Does not boot up just blank screen and then can not turn off
if it is not ur whole computer not turning on,it is ur o.s.,probly corruptedd,if it is ur computer that wont turn on,try replacing the motherboard.
Jul 16, 2010 | Acer Aspire One PC Notebook
I cant get my computer to fully boot up
This might happen if you install McAfee with applications running, or not restarting Windows, etc. I am not sure why you couldn't boot in Safemode, booting in safemode is exactly what you need to do to uninstall McAfee.
Mar 13, 2010 | Acer Aspire M5641 PC Desktop
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
My screen is black
Download the Sansa Recovery Tool for the Sansa e200 series and run the official Sansa Recovery Mode
or
Run Windows Recovery Mode
Try this: disconnect the player from the computer, turn it off, hold in the REC button, and reconnect the player to the computer while holding the REC button in. Keep holding the REC button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Mar 16, 2009 | SanDisk Sansa e260 MP3 Player
Have an acer computer, you turn it on, it goes to the acer screen then a window pops up that says not enough disk space for this app..or something like that. it turns off then goes back on, doing the same...
The Master Boot Record is corrupted so it cannot boot to operating system. Load your Windows CD and let it run, it will look like it is loading but it will eventually stop and ask if you want to continue or repair. Choose repair. That will fix it and then restart your computer.
Don't forget to rate this solution.
Jan 11, 2009 | Acer Aspire 5100-5022 Notebook
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5022 Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
