Question about Panasonic SC-HT280 System
Overload display on sa-ht280 panasonic receiver
redhead7377
  • 51 Answers
SOURCE: My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
Posted on Jul 25, 2008
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
SOURCE: panasonic sa-pt954. no sound. display says W1
NESESITO UN ENGRANES DEL CARGA DEL DISCO
Posted on Aug 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: After turning on Panasonic SA-HT
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 24, 2011
dunnbiker
  • 8546 Answers
SOURCE: i have recently purchased a
If it has never worked maybe your speaker connections are shorting.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 06, 2011
Need a power supply cord to my Panasonic SA-HT280. Where can I find/buy one?
find it on ebay or in store it will be cheaper online then the store
Aug 18, 2013 | Televison & Video
Have recently had an "overload" displayed. Have
HI:
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
Overload on Receiver-SA-HE200
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} you many have a fraid wire or if you playing the unit to loud and overload the amp this may cause it to go to protect. Also is the the receiver properly vented. If it get to warm the receiver will also go into the protect mode. hope this helps
May 25, 2010 | Panasonic SA-HE200 Receiver
DISPLAY SHOWS "OVERLOADED" MESSAGE
Disconnect all speakers at the receiver then turn the unit back on. If it stays on, post a comment and I will walk you thru troubleshooting. If it still shows "overload" it needs to be serviced. Hope this helps
Dec 22, 2009 | Panasonic SA-HE70 Receiver
My receiver (SA-HE70) shows overload on the display, I know that someone probably shorted the speaker wires. How can I fix this or get a service manual for it?
Diusconnect all the speaker wires. Still overloaded? Y= take it in for service. N= isolate which speaker path is causing the problem.
Dec 11, 2009 | Panasonic SA-HE70 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Getting overload display i have 4 ohm speakers hooked up to it
Receiver is designed for 8ohm speakers. you can't use car audio speakers. they are 4ohm. Most receivers will tolerate 6ohms but not 4. This will short the mains and destroy your power amp!
Nov 17, 2009 | Panasonic SA-HE200 Receiver
Overload displays on the screen
If it say's overload with no speakers connected and the unit on, it needs service. If you need further help, post a comment and I can help you troubleshoot.
Aug 11, 2009 | Panasonic SA-HE70 Receiver
Overload & shotsoff
i cannot get sound as my ac receiver says overload what can i do
Apr 18, 2009 | Panasonic SA-HE200 Receiver
Panasonic SC-HT280 System Logo
126 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
