Question about Samsung LN-T4661F 46 in. LCD HDTV
Samsung LN-T4661 when turned on picture comes on and then disapears voulme stays on
First it happened a couple times that it did not turn on at all ( the music cycle to start did not come on) blank screen. I thought it was the cable server so i tried a couple hours later and it worked fine, this happened a couple weeks ago and then yesterday it did not turn on at all, blank screen, no start cycle music, even contacted the cable co. and they tried at their end and say was the TV, I then again tried several times during the day and finally music cycle, picture on but it goes blank immediately and that's where I am at
  • 11 Answers
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
  • 6 Answers
SOURCE: samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Posted on Sep 01, 2009
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
SOURCE: Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
Posted on May 10, 2010
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
My ln-t4042h turns on and stays on for a while and then the screen goes blank then coming back on and off then stays blank. Also while it is actually working you can see the brightness fading in and out.
U have sound,after picture fated?Ur LCD inverter board it dead.must replaced this board to get the picture back.It usally a long board.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 06, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung lnt3232h has no picture when turned on. It does make the on/off jingle though
Ur power board is dead,must replaced to get picture back.Turn on/off couple times,wait 10-20 mins see if pic come on.100% is the power board.Not than ur Signal tuner board could be the cause.
Jan 12, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
Thmy samsung LN-T3242H - 2 years old - the picture
Hi:
Make sure under your audio options you are in stereo mode and not it SAP, (Special Aided Programing).
Dec 24, 2009 | Samsung LNT2642H 26 in. LCD Television
Samsung LN-T-4042H the picture is flashing. How
Look for screen setup for AUTO ASPECT in the setup menu, turn it OFF.
Nov 07, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Aug 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
I own a Samsung flat screen tv Model LN-T4661 for just under one year and I have a problen when i switch it on it takes 3 minutes to come on after a struggle with clicking on and off by itself for 3...
If your LCD is under a year old, I would suggest to contact the manufacturers to get it fix under warranty. It looks like the power supply is starting to fail or it could also be a main board failure.
Let me know if you require further assistance.
Jun 15, 2009 | Samsung LN-T3253H 32 in. LCD Television
Samsung LN-T4661F 46 in. LCD HDTV Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
