I need to change the water mixer valve but how do i get to it
  • Ron Coons
    Ron Coons May 11, 2010
    please list model and manufacture to assist further
  • 15,935 Answers
Remove the shell. It will be exposed for easy changing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Watermixernotlethotflow
Dear Ed,
To save some money and effort, get an electric meter and check to wires to the water mixer to see if the electricity is coming to the mixer when you tell it to use the "hot".
Then, check the filter screen either in the hot water hose (found on either end) or the hot water connection in the mixing valve.
They can plug up with sediment preventing water flow.
Finally, you can change the mixing valve it you are sure the electricity is coming to it during the hot cycle, and you are sure the water is flowing freely out of the hot water hose.
God bless your efforts.
Nov 12, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
I'm having a problem with my zanussi fla1101w the water dosen't get hot anymore. The hot and cold inlets are connected correctly thanx
sounds like a bad mixer valve -- it could be getting power to the mixer valve but it is stuck and not opening. use a meter to check for voltage at the mixer and if you have voltage then the mixer is bad and needs to be replaced. if you do not have voltage at the mixer then the problem could be at the main board.
c...
Feb 03, 2011 | Washing Machines
We have both hot and cold hoses going into washing machine but cannot get anything but cold or lukewarm water no matter what setting we choose. The pipe leading into the hot water hose feels warm and we...
sounds like the mix valve on the washer is broken and not opening properly -- the mix valve is the valve that both hot and cold water are connected to on the back of the machine.. turn off water valves and remove the hoses,, remove the back panel from the washer -- the mixer is held in place by one little screw,, also mark the wires going to the mixer ( hot/cold ) --- remove the mixer valve and take it down to your local appliance repair shop and match it up to a new one -- install the new mixer and connect wires and panel and then hoses and all will be working good as new.
c...
Feb 01, 2011 | Hotpoint Washing Machines
Water continues to fill machine,i can even have the machine off and unpluged and water will still fill machine
this is caused by a bad mixer valve. ( it is stuck in a open position ).
to fix this problem you will need to undue the hoses from the machine and remove the back panel of the washer, remove and replace the mixer valve. ( mixer valve is held in place by one small screw -- take note to what wires go to the hot side and what wires go to the cold side ).
c...
Jan 02, 2011 | Washing Machines
Water not hot at the Symmons Safety Mix valve. Had plenty of hot water before I installed a new hot water heater. Now, it's not as hot. I turned up the temperature to about 130 degrees. Sometimes it is...
There might have been some sediment that came thru the water line after changing the water heater and got into the mixer valve. You may need to shut off the water and clean out the mixer valve assembly.
Oct 27, 2009 | RTO Symmons Deluxe Temptrol pressure...
Machine does not turn off even if the cycle knob is pushed down in the off position. Water continues to flow when the machine is in the off position
Sounds like water solenoid valve has failed, it is fairly easy to replace. Valve is located near water hose connection
Jul 29, 2009 | Maytag Atlantis MAV8000
Fills with water when not in use.
Hi, If the washer fills up when off, you will need to change the inlet mixer valve. Do you have to shut the water source valve off to keep it from filling up?
Please let me know so I can assist you further.
Thanks
Vic
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
NO WATER OR SPARADIC WATER
Hi, Does the cold water valve hum when you start the washer? Put settings on cold and start washer. If the valve hums, remove the hose and check to see if there is sand or rust plugging the screen (DO NOT remove the screen) Just scrap it or flush it with the cold water hose. If the valve does not hum, you will need to change the mixer iblet valve. Please let me know if I can assist you further or order you the part you need.
Thanks
Vic
May 17, 2009 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
