Question about Husky Air Compressor. 2 Gal. Portable Electric Air Compressor and 4
Why wont my air compressor hold pressure - Husky Air Compressor. 2 Gal. Portable Electric Air Compressor and 4
    New Friend:
    Problem Solver:
  • 6 Answers
I dunno how it works but there should be a little pin on it and try pushing it in
Posted on Mar 08, 2013
My 60 gallon kolbalt was running and stop when it filled now it wont go o ever with the tank drain it spins free it does nothing no sounds either
When you say it does nothing do you mean the motor wont come on or the motor comes on and it wont build pressure? if the motor comes on, there are several possibilities:
1. The unloader valve is stuck open
2. The valves in the head are bad
3. The flywheel is loose
If the motor wont come on, the pressure switch is bad (which holds the unloader valve open)
http://www.mastertoolrepair.com/air-compressor-parts-vt6362-p-60727.html
Oct 10, 2016 | Kobalt 3.7-HP 60-Gallon 155 PSI Electric...
I replaced new air bags and air compressor it runs but wont rise the bags what could it be?
Get yourself a spray bottle with a bit of dish soap and water in it. With the compressor running start at the compressor and spray all fittings and lines with the soapy water. Look for bubbles indicating a leak in the system. You might also start by removing the pressure line from the compressor and hold your finger over the fitting and make sure the compressor is making pressure.
Aug 23, 2014 | Cars & Trucks
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Aug 20, 2012 | Craftsman Air Tools & Compressors
Compressor wont restart because of head pressure
Piston air compressors have to unload to permit a restart, the two mot common types are an unloader valve or free air unloaders.
with an unloader valve this system uses a check valve mounted in the discharge line as it enters the tank, when the pump stops this check closes and does not permit the tank pressure to return to the pump. a unloader valve also opens to allow air pressure in the discharge line to vent, this valve is either on the pressure switch or on some models is on the pump, and is a centrifugal type.
Free air unloaders or head unloaders are a set of fingers that hold open the intake valves on the cylinders to permit the piston not to pump air against a head load, and once the pump is running the fingers retract to allow the pump to function as normal.
Jan 19, 2010 | Air Tools & Compressors
Porter cable model 2005 type 3 wont build pressure
The check valve is most likely the problem,or the compressor is bad.The check valve actually holds the air in the tank,without allowing the air to retreat backwards into the compressor.
Oct 17, 2009 | Air Tools & Compressors
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
International air compessor mod frv 30650 orzc2015 wont hold pressure after 50psi
hi you say it wont hold pressure aftwer 50 psi /do you mean it wont make more than 50 psi
take air cleaner off get a piece of plastic pipe that will fit in your ear /braided fuel pipe is ok ,run the comp up ,put one end of pipe in inlet manifold /other end in your ear ,if you can hear escaping air valve is shot do the same with outlet valve if air escape is mimimum rings and piston are shot hope this helps silk090
May 02, 2009 | Air Tools & Compressors
Belt drive wont build up pressure
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). IF YOU REMOVE THE HEAD THEN MARK IT SO YOU CAN PUT IT BACK LIKE YOU FOUND IT. NOT TURNED OR FLIPPED OVER. ALSO IF YOU HAVE TWO PISTONS THE LOW PRESSURE PISTON COULD BE WORKING AND THE HIGH PRESSURE ONE ISNT. BROKE ROD OR VALVES. CHECK AIR FILTER. HOPE THIS HELPS. JODY
Apr 10, 2009 | Air Tools & Compressors
Husky Air Compressor. 2 Gal. Portable Electric Air Compressor and 4 Logo
129 people viewed this question
Top Husky Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Husky Tool and Hardware - Other Expert? Answer questions, earn points and help others
