Question about Video Cameras
Rca vhs camcorder cpr300 won't playback or record
When I put a tape in the camcorder just makes a weird buzzing sound as it tries playing. same sound when i try and record. I've tried multiple tapes and also tried taking the side off to see if a component isn't functioning properly, but I can't tell. Anyone with experience with older cameras, please help!
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Posted on Aug 02, 2007
  • 73 Answers
SOURCE: Scrambled picture & no sound on mini-dv tape
it sounds like your head needs aligned
Posted on Feb 23, 2008
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Posted on Jun 21, 2008
SOURCE: Canon ZR100 camcorder blue screen playback, tape eject beeping
no video record and blue screen
Posted on Nov 30, 2008
ripleymojica
  • 643 Answers
SOURCE: Panasonic PV-GS39 -- Eats Tape, Reset Button, Playback Problems
ya sounds like a bad tape loader. your estimate sounds about right. tape sensors also go bad so I would have them check it also.
Posted on Jun 01, 2009
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
My AKAI GX 636 records but can't hear anything on playback (had recorded tape play on another reel to reel) plus the VU needles don't move when you try to play a recorded or pre-recorded tape
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
Jul 18, 2009 | Audio Players & Recorders
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Feb 28, 2007 | Sony CCD-TRV228E Camcorder
Sony DCR-HC42 makes a buzzing sound
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
Video Cameras Logo
62 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
