Question about Lenovo ThinkVision L193P LCD Monitor PC Desktop
I moved my lenova desktop. When I reconnected it, I could get the desktop to connect with the monitor. It said the cable was disconnected or said power save. But all of the cables are connected?
  • Lenovo Master
  • 2,878 Answers
Check both end if your monitor has a detachable cable. Look for bent pins on VGA (blue) adapter. Make sure monitor is set for correct input, like VGA, DVI, or HDMI. Last is there a chance you video card is not loose and needs to be re-seated? Applies to add-on card only.
Posted on Dec 01, 2012
My dell 470 wont boot up every thing seems to be working but when i turn on i get a blank screen and no signal displayed Edward
This means that your monitor is not receiving a signal from your graphics card.
Here are the things that you can try:
-Disconnect and reconnect your monitor from your computer.
-Try using a different cable to connect your monitor to your computer.
-Try connecting your monitor to another computer, if it works there it means that there's a problem with your graphics card and it may require a replacement. If your monitor is still saying no signal even if it has been connected to another computer that works fine then the problem is with the monitor.
Apr 22, 2011 | Dell Precision Workstation 470 (204816690)...
Only says cable disconnected on screen
May be your monitor cable has been faulty.You can check it from service center.
Mar 24, 2010 | Dell E551 15" CRT Monitor
"Check signal cable" appears on the screen. I have disconnected
The cable that connects the MONITOR to the COMPUTER is loose or disconnected. Check the monitor cable at both ends. (not the wireless switch, router or modem).
Nov 13, 2009 | Samsung SyncMaster 205BW LCD Monitor
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
No powering on
Resolution:
Aug 24, 2009 | Dell Computers & Internet
Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
Why does everything that is displayed on my moitor have a blue tint to it?
Could be a problem with the video cable and/or connections. Try disconnecting and reconnecting the monitor cable and move the cable around to see it improves. If this does not change anything it may be an internal issue with the monitor or video card.
Nov 22, 2008 | Gateway Computers & Internet
Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the...
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
May 12, 2008 | Computers & Internet
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Lenovo ThinkVision L193P LCD Monitor PC Desktop Logo
59 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
