Question about Gateway CX2610 Notebook
Gateway cx2610 laptop hd password protected cant locate cmos battery
Started using my old laptop while mine is used for our business and I cant remember the password for the HD
  • Gateway Master
  • 32,281 Answers
These WEB sites may help you remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/
A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Posted on Dec 01, 2012
4 Suggested Answers
Whisperwolf
  • 110 Answers
SOURCE: Gateway 450 ROG will run only on battery.
If it's still under warranty, it's definitely worth repairing. If not, get them to quote for the repair they say it needs before agreeing to it. If their quote is anything close to the current price, I would say it's not worth it.
Posted on May 26, 2008
SOURCE: Where is the CMOS Battery for the gateway M320 located?
I have a BIOS password issue?
Posted on May 25, 2009
kamal1984
  • 1383 Answers
SOURCE: CMOS battery Gateway 450SX4 notebook
it is in back sdie of alptop.
You have to remove 4 screw on each side of square.
then you find motherbord chipset.
cmos cell is fixed on motherbord circuit.
Posted on Jul 16, 2009
My nephhew just bought a gateway w350a t series laptop at auction ,the bios is password protected,does anyone know where the cmos battery is ,i cant find it anywhere. i took off all accessable covers and...
The CMOS battery is attached to the underside of the motherboard. you will need to carefully disassemble the entire laptop to access it. If there is a bios password there is no way to tell if there is an issue with the HDD. I would start with removing the CMOS and then resetting the Motherboard using the reset jumper. You need to look up the board and find where the reset jumper is, probably through a web forum or the manufacturer website. after resetting and replacing the battery, you may still run into issues...the password may be set through a TPM chip. This chip stores the security settings in flash memory. The jumper may reset this also, but I am not 100% on that.
Jun 19, 2011 | Gateway Computers & Internet
Trying to enter BIOS on Gateway 7330GZ and it is requesting a password on a old dos type screen
To reset the bios you must clear the CMOS
There are two ways to approach forcing the Bios/CMOS to be reset to its default values: Option #1: Mechanically, by removing all power to the Bios/CMOS thereby forcing it to reset itself to its stored defaults, which include no password or the default password employed by the Bios manufacturer, and Option #2: Using a program to either locate and identify the password and reveal it to you or erasing the password entirely. These are referred to as password by-pass utilities or cracks.
Let's look at Option #1
By either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.
If the "Clear CMOS" jumpers are not present or not available:
Shut down the computer and disconnect the power plug. Locate, if possible, the instruction booklet for your motherboard. Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
for further information read
http://www.dewassoc.com/support/bios/bios_password.htm
May 02, 2011 | Gateway 7330GZ Notebook
How can i remove password from my loptop?
All mother board has a CMOS, complementary metal oxide semiconductor, battery. The main purpose for the CMOS battery is to store the system time, date and bios settings even if the computer is turned off or the main battery dies.
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings. (Password removed)
Apr 18, 2011 | Gateway CX2610 Notebook
How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
Aug 29, 2009 | Dell Studio 15 Laptop
My CX2610 Internal Mic Not Working
if you need it that much, dont bother wasting time with internal just buy an external mic they cost the same as a mcdonald burger.
Jan 21, 2009 | Gateway CX2610 Notebook
What i can do
Sorry to say nothing can be done. After password is to secure from unauthrized access. You may have to restore your computer to factory settings. This will remove all the data. You can contact a local technician to back up your data before restoring the laptop.
Jan 10, 2009 | Gateway CX2610 Notebook
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
Problem with ma ibm thickpad
loose the back of yr ibm if u cant find the cmos battery then u might need to disasemble the whole system carefully under the key board i think thats where th cmos battery will be.
Note removing cmos battery in some systems dont clear cmos password u have to do some additional work to remove yr password. for the battery prob try using a diff battery to be sure what ur prob is.
thank u
May 26, 2008 | Computers & Internet
Gateway Cx2610
You DO NOT need to replace the motherboard. Laptop jack can be replaced. This place can do it for you, you ship your laptop to them, they replace your jack, then send it back. It costs $99. A lot cheaper than a new motherboard! http://www.800tech.com/ And so you know, I am not affiliated with them in any way.
Aug 25, 2007 | Gateway CX2610 Notebook
Gateway CX2610 Notebook Logo
123 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
