I need to reconnect the power cord back on my RCA tv. I have the black wire soldered back on to the tv, but I don't know where the white wire goes. Thanks!
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
The white will go to the main On/Off switch.
Posted on Dec 01, 2012
3 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Posted on Jun 23, 2007
Shuttle83
  • 1139 Answers
SOURCE: LG 42PX4DV- black and white through external imputs only
Hello freudianslip,
Since you said that you moved the TV set and then this problem occurred, this leads me to believe that this is a case of mechanical failure (cold solder connections). I say this because so rarely does moving a TV cause a failure in the electronics of the TV.
Now to fix this problem one might suggest that you take a soldering iron and some solder and start locating the possible cold solder connections and touch them up. I will not suggest that, because most sets now have SMCs (surface mounted components) which require specialized equipment to remove or to refinish soldering work, even with the right equipment there is a chance of doing real damage to the TV set.
I say, since you know the approximate area of the problem (DVD inputs RCA Ports), you should relay this to a qualified TV repair person and then have them troubleshoot and repair this problem. I know this was not what you wanted to hear since this is a fix it yourself site, however as a owner of a TV repair shop I have had many people bring their sets in after effecting repairs on complicated electronics because someone gave good advise, but the skill level of the TV owner was not up to the level of the person giving the advise.
One the off chance that this is an electronics problem my guess would be the video processor section, in which case taking it to a TV repair shop is a wise decision also for the same reasons mentioned above.
I hope this helps
Thank you,
Shuttle83
Posted on Jan 20, 2008
I need to replace my electric cord on my Craftsman circular saw. I have the replacement cord and have opened the saw. The new cord ends with just a black and white wire. But the old cords black and white...
my best advice is to sever the wires going into the unit at a point where they are in good condition, obtain a soldering device and solder, some heat shrink tubing addtiquit for the size of wire and connect your new power cord to the these ends, make cretin that the common or wight and the hot witch is black be connected respectively
Good luck and best regards Falco Mueller
Oct 12, 2013 | Saws
I am trying to hook up an ancient Kenwood KAC-801 amplifier. The original input cable has 1 red, 1 black, then another smaller awg white (1) sharing a common with another small awg yellow. Applying power...
Yes, keep in mind that the amps have a constant power (the large red wire) and need a remote signal to tell them when to turn on/off. This wire connect to a switched 12v from the ignition or radio blue wire (if aftermarket)
Nov 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Need to reconnect dryer power cord. Black to
In most cases your black and red wires will be the hot wires and the bare(green) or white will be your ground and grounding wires.
Oct 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I need to replace the power cord
you will have to open up the back of the tv. This can be a very dangerous as there can be a lot of stored voltage inside even if its unplugged. If you choose to do it, look on the back of the circuit board for an empty connector that used to have the power cord. Sometimes they are soldered striaght in, Do you have a replacement? Also if there is some wire left you can splice the wires togeher without having to do any soldering.
Feb 03, 2009 | RCA 27F530T 27" TV
RCA TV F31317 - can't turn power on - suddenly, it stopped workin
just follow the power cord where it goes into the tv and there is a small glass fuse right there,check to see if the small wire inside it is burnt out or if the fuse appears to be white or black inside.
Dec 01, 2008 | RCA F31317 31" TV
Getting clear audio to televisions from a soundboard
I think you should buy a video sender. It will take audio from your audio console and send wireless to a free channel to any free TV channel. No cables!
Here's one on ebay:
http://cgi.ebay.com/Wireless-UHF-Audio-Video-Transmitter-Sender-4-Cable-TV_W0QQitemZ180307960679QQihZ008QQcategoryZ11726QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Nov 25, 2008 | Audio Players & Recorders
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power cord pulled out
i have just pulled the back by removing 5 or 6 screws. you can see the circuit board, and the power cord is soldered directly into the board. two wires,one black and one white. near the left back corner--- from the back. you can re solder it.
Mar 27, 2007 | Sanyo DS25390 TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
