Question about E-Machines eMachines Desktop PC
Manual for et1641-02w
Wiring hard drive and disk
  • ilmdalexus18
    ilmdalexus18 Dec 01, 2012
    show wiring connections from manual to wire computer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 64 Answers
Http://office.manualsonline.com/manuals/mfg/emachines/et164102w.html
Posted on Dec 25, 2012
Delayed write failed Failed to save all components for the file \\system32\\00007e87
HI...............
This error typically occurs when the "Enable write caching on the disk" feature for your hard disk is turned on.
However, if the "Enable write caching on the disk" feature is turned off, this error can occur because the Ultra Direct Memory Access (UDMA) hard disk controller may be configured in either of the following ways:
  • You are using a 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
  • The BIOS settings are configured to force faster UDMA modes.
For more information about the delayed write failure, go to the "Delayed Write Failure information" section.
To resolve this issue, first check whether the "Enable write caching on the disk" feature is turned on. If it is turned on, turn it off. To do this, follow these steps.
Note If you turn off the "Enable write caching on the disk" feature, your hard disk may perform more slowly and may affect the overall system performance of your computer. Because of this, you may want to monitor system performance after you follow the steps in this section.
To turn off Enable write caching on the disk, follow these steps:
  1. Click Start, and then click My Computer.
  2. Right-click the hard disk, and then click Properties.
  3. Click the Hardware tab.
  4. Click to select the hard disk, and then click Properties.
  5. Click the Policies tab.
  6. Click to clear the Enable write caching on the disk check box, and then click OK.
  7. Click OK to close the Local Disk (C:) Properties dialog box.
  8. Repeat steps 3 through 5 for each hard disk that is installed in your computer.
If these steps resolve the error message, you are finished.
If these steps do not resolve the error message, or if the feature is already turned off, go to the "Advanced Troubleshooting" section. This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/
Make sure that the hard disk controller is configured correctlyTo make sure that the hard disk controller is configured correctly, check the cable connection and the BIOS settings. First, try method 1.Method 1: Check that you are using an 80-wire, 40-pin cableMake sure that your UDMA hard disk controller is using an 80-wire, 40-pin cable. For information about how to do this, see the documentation that is included with your computer, or contact your UDMA hard disk controller manufacturer.
If you are using an 80-wire, 40-pin cable, go to method 2.
If you are not using this cable, obtain and use an 80-wire, 40-pin cable, and then test to determine whether this resolves the error message.
If this resolves the error message, you are finished.
GOOD LUCK................
Nov 10, 2011 | HP Computers & Internet
Boot disk failure no hard disk found
The error means that your system is not able to detect the hard drive on the system, check if the hard drive wire connections are tight and not loose and then try rebooting the system.
Look for hard drive stats on POST whether it succeeds or fails. This is how you can do that.
When system boots up, press the PAUSE?BREAK on the black screen and see whats system comment for your hard drive power test. If it succeeds and your hard drive's connections are also tight then possibly your hard drive might have crashed ( which means there are bad sectors on the hard disk).
Try performing disk checking on the hard drive to see if there are any bad sectors on the hard disk, the disk check will automatically fix the soft errors but if the errors and hard errors in that case the disk checking utility will not automatically fix the errors and you will need to get a new hard drive.
Thanks !!!
Nov 22, 2010 | Computers & Internet
I bought a third party ie seagate 160 gb sata hard disk and replaced in my laptop but windows installation disk did not find any hard disk present in the computer. how to install a third party hard disk ?
If you are installing Windows XP on a SATA hard drive, Windows installation CD does not have a SATA driver, that is why it does not detect the hard drive. please click on this link and follow my instruction to install Windows on a SATA hard drive :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Oct 31, 2010 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Hi i m hems i m upgrading hard disk on my ( acer aspire 1641nwlmi ) laptop hard disk is 160 gb but it's not detecting my new hard disk , my new hard is ok but i have quistion 160 gb is supporting my laptop...
The Aspire 1641 is supplied with a 80Gb hard drive. If the new 160Gb hard drive is not detected in the BIOS then the BIOS cannot support this size hard drive.
Check your manual/specification to see the maximum size hard drive it can support.
You can install the 160Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Aug 24, 2010 | Acer Aspire 1641WLMi Notebook
When I start it it says operating system not found, and stops loading!
When you start it up press f2 to enter bios. Go into boot configuration. Make sure the boot order is:
1. A:/ (floppy)
2. D:/ (cd drive)
3. C:/ (hard drive)
If the boot order is correct make sure your bios are registering your hard drive. If it's not then replace the hard drive. If it is then reformat and re-install the operating system.
Aug 16, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I think that the wires to the disk driver are in the wrong place, whats the right way they go in
Primary IDE Connector with Hard-Disk Drive To connect the PC-DVD drive to the primary IDE connector with the hard disk, perform the following steps:
  1. Back up the files on your hard-disk drive before you proceed.
  2. Set the jumpers on the PC-DVD drive as slave and the jumpers on the hard-disk drive as master (see Figure 11).
  3. Connect the power cable and IDE data cable to your hard-disk drive as shown in Figure 13.
Figure 13. Connecting the PC-DVD Drive to a Primary IDE Connector with Hard-Disk Drive
May 23, 2010 | E-Machines T2042 PC Desktop
Install new hard drive m280e
~er~ what do you wanna to say ? how to install new hard drive?
if yes,you can reference the article :Illustrated how to replace a laptop hard drive
hope it can help you
Jan 13, 2010 | Gateway M280E
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
