Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge pss26sgpass keep in defrost error code bc ?????
Cleaned every thing coils etc i touch the compressor relay on main board and everything works for a few days then it went back to bc code again
    Top Expert:
  • GE Master
  • 9,472 Answers
That is actually a "tc" error code.
This error means that the display board isn\'t communication correctly with the temperature control sensors which is why it\'s giving the error. It may stop cooling so you need to keep an eye out. Either way, try to unplug the unit for 5 minutes (don\'t plug it in early it\'s hard on the compressor). Plug it back in and see if the error goes away. If it doesn\'t, you need to order and replace your display control board because it\'s just not working correctly unfortunately.Here is the board to order.
Posted on Dec 01, 2012
peyton32034
  • 410 Answers
SOURCE: GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Posted on Jan 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: PTS25LBM GE Profile Defrost cycle messed up
The GE Profile Refrigerator has circuit boards and sensors are in the freezer that sends a signal to the circuit board to begin and end the defrost cycle. It is very possible the sensor or the circuit board are defective and will need replaced. I will help you solve this if you like. This refrigerator is complex and will take more discussion with you to complete the repair, I am here to help, let me know, Thanks, Sea Breeze
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Posted on Jun 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
aasc
  • 1606 Answers
SOURCE: coils keeping freezing up again
Yep , replace the # 4 and # 5 thermistors . The # 4 , is the small , white 1" long torpedo looking piece , clipped to the top of the coils on the left side , in the freezer , with 2 white wires going to it . This tells the control board , the temp of the coils , when to defrost , and when to stop defrosting . The # 5 thermistor , is located at the bottom left rear of the freezer ( or behind a small oval grill on the right ) with 2 white wires going to it . This thermistor , tells the control board , the freezer temp . The part number for both is WR55X10025 .
Posted on Oct 21, 2009
How do I manually defrost the unit
Worst case to defrost, clean everything out food wise and unplug and leave doors open until it all melts. It sounds like the coils are dirty so the unit keeps running until it freezes over. Try cleaning all the coils, the compressor, etc, and when you try it make sure that there isn't anything in the way of the airstream
Jun 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
I have a GE gsl25jfta bs side by side, the freezer melts ice box then freezes it again.. Making a block of ice
Sounds like you could have a bad mother board. Very common problem with the GE models. It will shut compressor off, than everything starts to melt, then it comes back on. Replace main control board and it should resolve your issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/keith_6cb11225ab437567
Jun 18, 2014 | Refrigerators
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Hello, my frig gets real cold but one day compressor stopped frozen stuff started melting. unplug plugged in few hours later it works for a week off again cycle continues for a few weeks. I replaced the...
0ba250e7-c31b-40ec-b003-ff0da31d62e4.jpgThis could be caused by a couple of things. If the condenser fan is defective and stopping while you don't see the fan stop it will cause the compressor to overheat and stop. The other possibility is a defective=> 12784415 Main Control Board or JAZZ Board A defective relay on this board will cause the same symptoms, Sea Breeze
I am here if you have questions...JT
Sep 21, 2013 | Maytag Refrigerators
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
How do I troubleshoot GE GSS25LGPABB sbs: no freezer, now no fridge?
everything runs through the computer board on the back of your machine,part number wr55x10942.pull your machine out away from the wall and on the back right side bottom you'll see the cover for the board,unplug the machine and remove the cover,look at the board,you'll see black relays on the board,the new board has all 7 relays,if your board doesn't have all 7go here and see it most likely this is your problem.everything runs through the board,have you noticed your fans running at different speeds or anything else like that
http://www.repairclinic.com/PartDetail/Main-Control-Board/WR55X10942/1531075another thing it sounds like you have no compressor,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer over to the fridge side so if the freezer is down the fridge side is going down too.here's a picture of the board
http://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/
if you look at the diagram it tells you that if you jump out j8 and j11 the compressor should start,i've never done this but i did jump out j9 and j11 to check the defrost heater and thermostat.hope this helps you out and good luck,also if you do jump it out and the compressor doesn't run you can check the overload and relay on the compressor for continuity but most likely you have a bad computer board.
Sep 02, 2012 | GE Refrigerators
GE (PSS26SGPASS) Side by Side Refrigerator has been tripping circuit breaker. The compressor is very hot but seems to be functioning properly since the freezer is at 14 degrees and refridgerator side is...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | GE Refrigerators
Hello, I have a few problems with a GE side by side refrigerator. It's a model GSS25JERF CC. First problem was getting no water, then I was sometimes not getting any ice from the door even though the tray...
Trouble described as
EVERYTHING "appears" normal ... "Nothing works"
I have experienced a similar circumstance...
(much older machine)
But I'll stop here & go look for your DEFROST Timer (No)
Or CONTROL BOARD... (Yes, yours = WR55X10942)
Defrost timers can mimic this if the
mountings are loose and the ...
motor runs on "ground" rather than "neutral" (v-rare)...
but circuit boards do fail & cause these issues
easy to change (right lower side on back (@ freezer))...
Purchasing a SPARE
now could save you another
significant food loss & inconvenience in the future
Easyapplianceparts $141.24
Main Electronic Control Board
Appliancepartspros $142.99
GE WR55X10942 Main Control Board AppliancePartsPros com
See video guides
http://www.appliancepartspros.com/ge-main-control-board-wr55x10942-ap4436216.html#videol
Partsselect
http://partsselect.com/
Owners Manual
GE ESH22XGRECC Owner Manual And Installation Instructions Page 72
Mar 24, 2017 | GE GSS25JF Side by Side Refrigerator
I have a model gss25lgmb bb. Im having issues with (couple of months) my fridge randomly stop cooling. Causing everything to defrost. My fan still seems to be on but not cooling or freezing. PLEASE HELP
If its not cooling or freezing then the compressor has to be checked.The compressor is the part which controls the cooling and freezing in the refrigerator.If the gas / refrigerant in the compressor gets low/ less then compressor will run more but it will not cool due to less refrigerant in compressor.In that case the compressor needs to be replaced. -------------- Also it can be faulty defrost assembly parts causing this issue.The thermostat is got faulty or the heater is not turning off.This also causes every thing to get defrosted.
The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.------------
Before that you can try manual defrost reset procedure. The manual defrost reset procedure is as follows : ----First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again.Then go for replacing the parts.-------------------This should help.Thanks.Helpmech.
Apr 06, 2011 | GE GSS25LGM Side by Side Refrigerator
I have a stainless GE profile PSS26SGPASS side by side fridge and suddenly the freezer and fridge wont hold the temp settign I put. The fan works, the controls work to lower the temp setting but it isn't...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 26, 2011 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
530 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
