Question about RCA Raptor Loca25 2-channel Line Output Converter
I dont know what the wires on my raptor line output convertor stand for
Regal raptor drum brake shoes
Hi Anonymous, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day. 50cc Mopeds 125cc Scooters Motorcycles Motorbikes for Sale at AJS http://www.ajs-shop.co.uk/
AJS Regal Raptor DD 125 04 06 Manual Haynes
Jan 23, 2014 | 2010 AJS Regal Raptor DD50 E2
My 2001 raptor wont start
if the seal was broken on the engine, a seal was not insalled right and came loose, which in return u would lose vacuum in crankcase, going to have to tear engine down and double chk everything, this just happend on my quad hope this helps, that is why they call them toys! they can be frustrating
Jan 04, 2013 | Motorcycles
Im tryin to hookup aftermarket subs but the lineout converter isnt working, it sounds like alot of treble comin outt of the subwoofers. is there anyway to find a low frequency wire to tap into for the subs
instead of finding a low frequency line to attach to your LOC (line output convertor) use the built in crossover on yours subwoofer amp or an external crossover to limit the frequency range going to the subs
May 07, 2011 | Car Audio & Video
Problem with raptor 660
There is a manual available for you freebies:
http://www.carlsalter.com/motorcycle-manuals.asp .
And will help with any further work you do on the bike.
Feb 04, 2010 | 2004 Yamaha XT 660 R
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Transmission removal
The starter must also be removed and the 4 torque convertor bolts need to be removed, after that only the shift linkage remains and out it comes.
Jan 15, 2009 | 1994 Ford Explorer Limited
Engine swap
Hi, is not that hard,the steps are similar to RWD just be sure to remove the big nuts at the axels ends before you lift the vehicle,they are very tight and is veryhard to do it with the car up in stands,disconect all wires, muffler ,gas lines lift and secure the vehicle ,remove both axels, you have to remove the lower ball joints and tie rod ends to disconect the lower control arm to remove the axels , starter, motor mounts, the bolts that holds the trany,and the bolts at the convertor if is automatic,
Dec 01, 2008 | 1999 Daewoo Nubira
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
RCA Raptor Loca25 2-channel Line Output Converter Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
L Pfaff
L Pfaff
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
