Question about Panasonic CT-32HC14 32" TV
I got a ct-32hc14, tv will try to turn on but it quickly turns itself off and after that the led keep flashing once every two seconds
    Master:
  • 879 Answers
Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Posted on Dec 01, 2012
hardrocko
  • 1476 Answers
SOURCE: TV does not turn on
You have a short in your unit somewhere or a high voltage problem. The most common problem would be a high voltage failure. If you are not familiar with televisions and their safety this is best left to a repair shop. There is not much in a TV that consumers, unfamiliar with the system, can check. The problem should not cost too much to fix. Check for a shop which has a free estimate or low estimate which will be subtracted from the cost of the repair if you choose to have the unit repaired there. Good luck.
Posted on Jul 12, 2006
techman
  • 3130 Answers
SOURCE: Panasonic CT-32SF35 32 On & Off, On & Off
Bad capacitors in the standby power supply most likely.
Posted on Jun 09, 2007
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
  • 93 Answers
SOURCE: panasonic tv ct-32hxc14j
try to reheat or resolder your tv.
Posted on Oct 23, 2007
johnnydiode
  • 647 Answers
SOURCE: panasonic CT-36HX42F I turn it on and then, turns off
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom.
The only way to determine the real cause is #1 an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Posted on Sep 20, 2009
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
When trying to set up my new SRP2008B remote should the TV be on or in standby mode? In step 2 should the red LED be flashing or stationary? The Quick start guide is somewhat ambigious about these two...
U are setting up a universal remote?Yes,tv should be on,second push the search button on the remote,should be flashing and enter all those codes provided by the manual one by one the LED light of the remote should be solid red as the codes enter one by one the red light and go off and pushing the on/ff button on the universal remote for each codes as u got the wright codes the tv will turn itself off.
Apr 11, 2011 | Philips Televison & Video
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
TV wont turn on?!
What type of tv is this ? If it is a GE or RCA you might have a bad flyback transformer.
Feb 22, 2008 | Televison & Video
Panasonic ct-36hl43 tv
Sep 07, 2007 | Panasonic CT-36HL43 36" TV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
See all Panasonic CT-32HC14 32" TV Questions
Panasonic CT-32HC14 32" TV Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
