Question about Whirlpool GS475LEKS Gas Kitchen Range
What does E2 - F3 - code mean on a Whirlpool Accubake Gold??
I have an almost 3yr old Whirlpool Accubake Gold gas slide in range - as of late when I am baking or otherwise hit will all of a sudden spike to a very high temperature and burn everything in minutes - an code of
E2 - F3 - pops up, I turn off oven immediately and this will pop up again. It takes some time for oven to cool off and then won't do it for a few uses again and then all of a sudden again.
Why don't the manuals have any section to explain these codes and why does this happen?
  • 1 more comment
  • don-chan Jan 13, 2009
    I have exactly the same problem. Bizarre. Any advice appreciated. You should see the lasagne.
  • Anonymous Jan 15, 2009
    This too.
  • golf_247
    golf_247 Feb 06, 2013
    oven won't turn on. Green "start?' come on
  • Whirlpool Master
  • 2,651 Answers
F3 - E2 Oven too hot Replace oven temperature sensor
Posted on Jan 11, 2009
E2 f3 error code on whirlpool range
Here is the listing for this error code.
F3 - E2 Oven too hot Replace oven temperature sensor.
Here is the part to order.
Dec 01, 2012 | Whirlpool GS460 Gas Kitchen Range
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
Oven doesnt heat, after a few minutes displays error code F3 E2
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
My whirlpool gas range has the letters E2-F3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%
Oct 19, 2009 | Whirlpool Gold GW399LXU Gas Range
Whirlpool accubake self clean oven. Error code(s) E2 - F3?
You can get all the codes here.
F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
Good Luck and Please Rate FixYa!
Jan 07, 2009 | Whirlpool RBS305PDS Electric Single Oven
I Have a Whirlpool Gold Glass top Range. The Most Recent error code reading from left to right is E2 F3.
Hello welcome
Error code E2 means to
Check door/latch switch
Replace door switch if defective
Thank you Huum
Please leave a rating before you leave
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Whirlpool Super Capacity 465 gas stove
Find the paper in the envelope on the back of the stove. (Behind the console.) This will tell you what those fault codes mean. Be sure to replace the paper. If it is needed again, that is where a technician will look for it.
Mar 31, 2008 | Kitchen Ranges
Whirlpool GS475LEKS Gas Kitchen Range Logo
2,484 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
