Question about HP Laserjet 2200d 2200 C7063a Workgroup Printer With Toner,usb
My hp Laserjet 2200d printer won't print and continues to have a blinking orange light
Have asked it to print, the printer starts to react and then nothing happens. I have opened the paper drawer and closed and sometimes that works to set the printer off and I get 104 pages of a 64 page doc. Sometimes I am required to open and shut the lid to the toner area and it works. Other times NOTHING happens. I run a secretarial service in New Jersey and the paperwork for one of my customers wouldn't print and I had to send the documents to a disc, give him some of his letterhead and send him to Staples to have the estimates printed. Not a good way to do business. HELP!
adib
  • 450 Answers
SOURCE: can't open my home page
Try to soft-reset your iPAQ; depending on the model of iPAQ you have the soft-reset hole is located on the left hand side or bottom of your iPAQ; press the tip of the stylus into this hole to reboot your iPAQ.
Posted on Sep 11, 2005
JeJe
  • 3 Answers
SOURCE: Problems regarding web pages,
Are you using Pocket Internet Explorer? Try emptying the cache.
Posted on Mar 17, 2007
SOURCE: SETTING PAGE TO LANDSCAPE
The factory-stock 1940, which uses Windows Mobile 2003, doesn't offer landscape mode.
You can get a 3rd party program called Nyditot Virtual Display that will let you use the 1940 in landscape mode, but I've used it before, and although it works, the problems it creates are not worth it. Besides, that program's not free.
Adobe offers a pdf reader for free that let's you read pdf files in landscape mode.
Posted on Jan 28, 2008
CompuGuy44
  • 432 Answers
SOURCE: Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Posted on Feb 03, 2009
  • 10 Answers
SOURCE: MY HP 6515 gives me trouble: I can Lock on to the
THAT ONLY HAPPENS WHEN UR NOT CONNECTED TO INTERNET OR SETTING ARE SCREWD
Posted on Feb 21, 2009
I receive the following message on the PC display: "Document printing cannot be executed because the paper output tray is closed. Open the paper output tray. Printing will restart". I want to mention
The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
Dec 20, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Minolta Di3510 indicates paper tray jam. I check the tray and open all jam clear areas but find nothing. Close everthing back up indicator goes away and when system starts to print again the machine...
Paper feed clutch is bad. I see this all the time. You can get the machine running by opening slightly the drawer that the machine is trying to feed from. Delete the current job and let the machine use the other drawer until you get it repaired.
The feed clutches in this series are small electromagnetic clutches and they do fail from time to time. Part# 9322-1500-12. Don't pay more than around $60 for the clutch. Here is a pic.
Good Luck and Thank You for using Fixya.
Apr 19, 2010 | Office Equipment & Supplies
KONICA MINOLTA magicolor 5430DL don't recognize paper
The machine keeps track of what paper was reqested last, and asks you to change paper if the new job is different. I get the "put media" message and have to open and close the drawer if my next print job requests a different paper. So I suggest you gently open and slam the drawer a couple of times, or see if you can find the sensor switch that monitors whether the drawer is open. Also check if your paper guides in the drawer are clicked in place.
Sep 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
Brother HL-4040CN Laser Printer does not feed the paper and stops. I open the paper drawer and the paper will be just above the drawer and I will push back down and close the drawer. Sometimes it will...
i have brother 4040cn printer but its not working any more its showing me no paper load paper in multi purpose tary.
so fi any one there for help me please help me .
thank you
Jan 28, 2009 | Brother HL-4040CN Laser Printer
MFF6550 Printing nothing but white paper.
I unplugged my printer for 10 minutes and then plugged it back in. It went into an initialization mode and was fine after that.
Nov 15, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
HP Laserjet 2200d 2200 C7063a Workgroup Printer With Toner,usb Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
