Question about Sony Televison & Video
Sony WEGA KE-42XS910 will not recognise HD antenna input signal and states no signal
Set will play both tapes and discs. Antenna input works with another Sony and a Panasonic set.
    Master:
  • 879 Answers
Check and replace its tuner. It is faulty. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Posted on Dec 01, 2012
  • 257 Answers
SOURCE: Sony Wega Trinitron HDTV Blue Screen with Sound
It means the TV does not receive signal from the box. Try the follow step to isolate the problem.
Use the same HDMI cable from cable box and hook up to another TV that has HDMI input (if any). If it works fine (picture and sound), HDMI cable no problem. If it does not, problem might come either from the cable box or HDMI. You may have to buy another one. If it still does not, call the cable box or the Best buy guy. Hope it helps.
Posted on Aug 11, 2009
Testimonial: "Swapping cables didn't work so I called the cable company, walked me through resetting the box, which seems to have solved the problem. Thanks."
SOURCE: set up Sony Wega TV on Video 2 for a Wii system
In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
Posted on Dec 28, 2008
joboo1
  • 257 Answers
SOURCE: Is this TV a digital tuner? or will I need a converter box
Hi, If you have an outside antenna you will need a converter box as this tv has an NTSC tuner which is analog.
Posted on Feb 02, 2009
SOURCE: Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Posted on Sep 07, 2009
SOURCE: Sony Trinitron XBR's integrated HD tuner problem
buy technical Sony docs on Ebays :
SONY TV SERVICE & REPAIR MANUALS ON DVD + 400 MODELS 12,99 USD
and good luck : Thierry
Posted on Sep 27, 2009
I bought Philips antenna, SDV1125T/27. Still I can't get my old tv to work. MY tv is old Toshiba 26AF45C.I'm not sure I bought the correct antenna.Please help
That TV will longer work with any Antenna by itself..the reason is a few years back the government mandated all TV signals will be HD. they sent out HD receiver boxes to allow old non HD TV's receive HD signals...I have a TV in my camper with the receiver Works great...Just see if you can locate one..there were thousands sent out..so they are out there Try Ebay..good luck.
May 02, 2015 | Philips Televison & Video
How long does it to turn on
It will turn on with just the power cord but nothing will show until hooked up to at least an antenna
Feb 21, 2015 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Set top box
If you are using only an antenna (digital tv) with no other company involved (cable dish, etc) you do not need any additional boxes to get the digital signal as the tv has a DTV input. All you need is connect the antenna, switch the tv to that input number, then use the remote to go into the settings area, change the antenna type to digital, then run a scan to find all available digital signals in your area. You should be all ok now!
Good Luck!
Rich Lilja
Dec 20, 2013 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
PICTURE SEEMS TO BE BLURRED WHEN ITEMS MOVE FAST ON SCREEN, ESPECIALLY PERSONS IN CLOSE UP.
The Sony Bravia KDL-32BX320 generally gets excellent reviews (4.5 stars out of 5) from owners, so I have to wonder what you're watching.
This is an HDTV and should excel when provided an HD signal to display. SD (standard definition) signals often look worse on an HD display than on an SD display. An HD signal is only available via the following ways (reference the image below):9_27_2011_4_28_11_pm.jpg
1) An "over the air" (UHF / VHF) antenna is connected to the cable / antenna input and there is a broadcaster of HD content nearby (only an over the air antenna can input HD signals to this jack - no cable boxes, etc.).
2) An HD Cable TV, DirecTV or Dish Satellite set top converter, Blu Ray Disk Player (or other HD source is connected via HDMI or Component RGB jacks.
3) An HD video played back from a computer hard drive connected to the VGA jack (when the computer is equipped with a modern processor and video card).
You will NOT be able to view HD video if:
1) The source material is a SD (non-HD) source. An over the air antenna will not provide HD signals if the broadcaster does not have HD content to show or is not capable of broadcasting in HD. Digital is not necessarily HD.
2) The source material (other than over the air antenna) is connected via Antenna / Cable jack.
3) The source material is connected via Composite jacks.
The USB jack is generally not an input for motion pictures, but may display stills - depending on the TV's ability to play the format they are stored in (jpeg, gif, bmp etc.).
Hopefully, this will help you solve the problem you're having with the picture. Good luck!
Sep 27, 2011 | Sony Bravia KDL-32BX320
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Feb 16, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Screen message- channel fixed. how do I get it to program channels in our ares ( direct tv satellite system)
If you are on a sat system then you only need one channel programmed, if you are using the cable input, if you just want the channels scanned for a local antenna, then you need to go to the menu and go to programming and change the cable/ant to ant and program.
Dec 13, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
For some reason, the component video input on my Sony Wega KE-42TS2U plasma HDTV will not work. Component video is on video 3. All other inputs work fine (coaxial, standard RCA inputs, and the digital...
Yes you need a new Q board most likely, if you audio fails after a while and your other inputs do as well then for sure you need a new Q board. It may be B board but I highly doubt. Atleast with my experiences with the KE-42TS2U.
Feb 21, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
