Question about Compaq Presario Notebook
COMPAQ presario cq57 has a blue screen and white curser
When i turned on the pc the screen appeared. right before then a lighter blue box popped up saying "dumping cash files" Please help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
This means nothing specific, try to load Last known good configuration, by holding F8 key right after power on, until it shows Windows boot options. You should also check memory, hard disk drivers and viruses, but this is much longer explanation, so ask if needed.
Posted on Jul 21, 2013
  • 383 Answers
SOURCE: Getting a blue screen on Compaq Presario M2000 Laptop
Blue Screen of Death - BSoD Also known as a bluescreen or bugcheck in Microsoft Windows NT, 2000, and XP, BSoD is short for Blue Screen of Death and is a full blue screen error message .
MS-DOS edit command help edit c:\autoexec.bat = This would look at the autoexec.bat; However, if the file is not found, you will have a blank blue screen.
Good Luck! Read and follow instructions/Please dont for get to Vote/Thank You.
Posted on Dec 26, 2007
Joed911
  • 4338 Answers
SOURCE: Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Posted on Oct 12, 2008
FoxSysPCTech
  • 107 Answers
SOURCE: Compaq Presario SR5140IL Desktop PC Xp Drivers
That computer doesnt come installed with XP you will need to find out who the original manufactuer of the devices are and download them. Intel makes it easy, they have a little tool that scans for their chipsets. You can use the vista drivers as a point of reference, for example, the Vista drivers section says it has a conexant PCI modem. If you find out the exact model number on your modem, you can go to conexant.com and download the proper driver. If they do not have it on their website, then you can find another computer that has the same hardware that was shipped out with XP and download the driver from that model. It should work without any problems. The hardest part will be finding all the model numbers for all of the devices.
Posted on Jul 17, 2009
  • 691 Answers
SOURCE: My Compaq Presario f500 series Wont turn on anymore
I would like to help but it sounds like it's over heated and needs a repair guy to look at it
Posted on Jan 11, 2010
  • 362 Answers
SOURCE: my compaq presario cq60 says
thats like my computer and should have a recovery partition on the disc try to fix from there ok its f11 on the start up menu
Posted on Nov 17, 2010
Half my screen doesnt work on my compaq presario. How can I do a factory restore if I cant see the screen and what option to click
I would definitely not try to do a factory restore without a full screen showing. Are you saying that the external monitor does not work for system restore?
amazon seems to have replacement LCD screens for $51.93
http://www.amazon.com/COMPAQ-PRESARIO-CQ57-229WM-SUBSTITUTE-REPLACEMENT/dp/B005IUFKKW
Sep 25, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Compaq presario cq57 my screen turns purple
Hello there!
It could be one of these:
1) bad monitor video pixels array.
2) Bad Video Card (heating)
clean your fan, for heating!
Apr 20, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
I have a Compaq Presario CQ57 running Windows 7. When I use the webcam it loads and streams video fine, but only for the first 3-5 minutes. After that it zooms in to the upper right (as you look at the...
What program or browser are you using when this happens. Does this happen on a full screen? If so try using it in a window. Close all applications and programs before starting the cam.
Nov 02, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
Sir my compaq cq57 in xp install blue screen on bios setting in not sata option found
Your machine, Compaq cq57 originally came with Windows 7, Correct?Remove the HDD and test, replace if necessary.
Mar 18, 2013 | Compaq Presario Notebook
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 01, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
How to replace cq57-229wm screen
HI,
On amazon you can purchase display for affordable price
Amazon com cq57 229wm screen. Take a look, but be awero... read reviews first.
regards
Mark
Jan 31, 2012 | Compaq Presario, Compaq EVO, Compaq...
Starts but black screen, white curser flashing.
your hard drive is failing. try a system restore and if that does not fix the issue you need to buy a replacement hard drive
May 13, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
My compaq V2000 pop up appeared
it might be your mouse setings for your left and right bottons
Jan 02, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario Notebook Logo
192 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
