Question about Dynex 32 in. LCD Flat-Panel HDTV
Dynex 19 LCD
Hi - I've connected my TV to my PC through the PC link and I am geting a picture, but at low res. When I try to bump up the resolution, the lcd goes blank and I get a message 'signal not supported'. Any ideas?
Thanks,
    Problem Solver:
  • 5 Answers
Yes, the current video driver is not configured for the higher resolutions supported by the Dynex TV/monitor. I ran into this same problem setting up my system. The solution is simple and only requires that you uninstall your current video driver and reinstall with the latest version driver for your systems VGA. You should be able to run the monitor at a resolution of 1440 x 900 with Color Quality at 32 bit Highest. Hope this helps.
Posted on Jan 11, 2009
2 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
Posted on May 29, 2009
Dynex 19 inch lcd tv does not show picture standing up but will show it laying down
check the ribbon cable that connects the screen to the mainboard may have a loose connection
Feb 02, 2013 | Dynex DX-LCD19-09 19 in. LCD TV
How can I connect my Dynex DX-32L151A11 32" LCD
The main set up is that you need to set your PC video resolution to the native resolution of this TV in PC mode otherwise the pictures will look real bad and not clear. No driver needed.
To use the TV as a monitor will not be as good as the PC monitor due to limited resolution the TV can display.
Here is the user manual:
http://www.dynexproducts.com/cms/documents/DX-32L151A11-37L130A11_10-0567_WEB_ENG_V1_Final%20lr.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 01, 2011 | Dynex 19 in. LCD Flat-Panel HDTV
My samsung 19'' lcd tv says 'not supported' when i connect my pc using the vga socket
hi,
the issue here is your pc vga card resolution setting, might be too high. try lower down the resolution and it should work.
Mar 29, 2010 | Samsung SM932MW 19 in. LCD TV
Horrible fuzzy display on my external lcd tv monitor - sadness
You need to change the resolution and colour quality under graphics properties on second monito. Put the settings back under the advanced tab, your just pushing new monitor over its limits. You dont need to have the same resolution set as your PC screen. Hope this works for you.
Mar 18, 2010 | ASUS Eee PC 1000HE Netbook
Does a dynex tv connected via vga to PC come up as a genaric monitor in windows display panel? Is this normal? or is there a way to make it identify it as a large screen tv for better resolution range?
If windows cannot identify the monitor that you have connected it will show up as a generic monitor. If you are able to find a driver for the monitor then windows will show that particular monitor instead. If Dynex has a website you can check there to see if they have a driver for your TV, or you can check under there support section to see if they suggest anything that might help.
Mar 02, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
I keep getting a does not support message when trying to connect to pc
The TV's screen resolution specs must match to what the computer can put out. If they are out of range of each other they will not function together.
Consult both the computer manual (external display section) and the TV manual for details.
I am assuming that you are using the proper cables, and the computer has the option to run an external display.
Jerry G.
Jan 19, 2010 | Dynex DX-LCD19-09 19 in. LCD TV
I'm trying to get my dynex 19' tv hooked up to use as a computer monitor and it will not work,keeps coming up "no signal",how can I fix it? HELP PLEASE!!!!!
lower the resolution in your pc first to 600 /800 then try if that works then you can try raise the resloution slowly
i believe the unit will only go as high as 720
Nov 24, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
I tried to connect my PC to the TV, but it said the mode was not match. How the PC fits it?
You need to adjust the resolution settings of your computer. This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspxin) in the frequently asked questions section on page 9. To adjust the resolution on Windows Vista: 1.Click the Windows icon to open the Start menu. 2.Select and click on Control Panel. 3.Click on Appearance and Themes. 4.Click Personalization. 5.Click Display Settings. 6.Select Monitor 2. 7.Drag the screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger or drag the slider to the right to increase the resolution of your monitor, making text and pictures appear smaller. 8.Click Apply to have the new resolution take effect. 9.If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No and adjust the resolution using the screen resolution slider. 10.Click OK. If this solution does not work for you .You can copy the above web address and paste it into your address bar. There you will find the support section. You can use the support e-mail to talk to the customer support people about the problem you are having connecting your computer to the television.You can also call the customer support at this telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of you television and tell about your problem. I hope this information helps you with your problem.
Jun 05, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 19 LCD
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Nov 17, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
922 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
