Where can I find a schematic diagram fot Enermax EG465P-VE ATX
  • 105 Answers
You can't found any diagram for and specific ATX PSU
but there are some generics
Posted on Dec 21, 2012
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: schematic diagram for ATX-250-12E
Once upon a time . . . I actually repaired PC supplies but only for some oddball PCs whose makers were too stupid to buy 'off-the-shelf' supplies from others.
There is a good possibility that replacement parts to repair one of these will cost more than a new replacement supply. You just cannot compete with people who earn a couple of dollars a day assembling them.
They aren't tough to repair if you have some technical skills but it just isn't worth it.
I'm pasting part of a post below I just did for someone else who wanted to know if the board could be damaged from a failing supply-
"Since there have been some changes in available outputs and connectors even on ATX supplies, make sure you compare pictures of the supply to your own but in any case, I would recommend using a replacment rated at 350W as this will run more conservatively and not be as stressed as the 250 you now have. It won't cost a lot more and will not consume any more power but the critical components will run cooler.
Not as a recommendation, just a current example on eBay:
http://cgi.ebay.com/Mustang-Switching-Power-Supply-350W-Model-LC-B350ATX_W0QQitemZ250294363195QQcmdZViewItem?hash=item250294363195&_trkparms=72:1156|39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
 The last couple I bought were $5 each with $7 shipping charge from a US source."
Posted on Sep 19, 2008
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
What fuse is in a Enermax EG495P-VE Noisetaker 485W Power Supply
Just buy a new power supply. If you touch the wrong thing inside that psu you will die. Seriously.
Aug 15, 2012 | Enermax (by Coolergiant) EG495P-VE SFMA...
SCHEMATIC DIAGRAM FOR ATX250-3505
While this link will show you a schematic for a 200 Watt ATX, the one you seek should be similar.
http://www.pavouk.comp.cz/hw/en_atxps.html
Dec 29, 2011 | Astec 250W Power Supply w / External Fan...
No display on the PC screen, i bought a case speaker, it made it noise it's suppose to make however, after putting in one memory stick, the problem remained unsolved
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 31, 2011 | ASUS P5G41CM Motherboard
My computer will not power up at all been looking for another compatible power supply since this one is discontinued need help immediately.. enermax eg425p-ve
I'd check into a DiabloTek PHD650 650-Watt Power Supply. It's a higher voltage module, but has similar features to your Enermax power supply. If you can't find it locally, check out TigerDirect.com (my fave) or NewEgg.com. These two sites are likely to have these, and are competitively priced.
Aug 31, 2010 | Enermax Noisetaker EG425P-VE...
Dishes do not come out dry and this has just begin happening.
I'll assume you refer to a dishwasher and not a PC. If the internal pump does not get all the water out, then the resulting pool in the bottom will inhibit the dry cycle. When it has reached the end of the washing cycles, open the door and see how much water is left. Then you will need to find out why that is, if there is a lot remaining. Could be a clogged screen on the pump.
May 26, 2010 | Enermax 431W Ultra Quiet ATX Power Supply:...
Enermax EG495P-VE (Off warranty) will run for 1 sec to 1 min and then shut down. No volts to 12/5/3.3. For the brief time that it stays on it supplies the correct volts under load. Is there a overload...
It's probably an accumulation of lint, dust, pollen, and anything else in the air over time, if you're lucky. This isn't the easiest of things to do, but you will have to use a small brush for a lot of clingy stuff, to compressed air for most cases. It could be a slight short in the fan motors, or a bad electrical connection or connector that's causing the current to rise and trip a thermister, or other heat sensing device. I would take it apart and see what I could see. Most of the time it's something simple, never know till you look.
One thing...if you do find an overload switch or circuit, figure out the problem that's making it overload. It's probably not the switch that's bad, but something else. Good luck!
Mar 27, 2010 | Enermax EG495P-SFMA24P Very Quiet...
Power supply , small plug hook up?
That plug is for the fan RPM monitor, it is not needed for normal operation.
Mar 06, 2009 | Enermax (by Coolergiant) EG495P-VE SFMA...
Schematic diagram for ATX-250-12E
I repair power supplies and various electroics, most cases it will be compacitors, or diodes which have caused it to fail!!
Jul 29, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Computers & Internet Logo
348 people viewed this question
David Payne
David Payne
