Question about Canon PIXMA iP4200 InkJet Photo Printer
Pixma4200 header stacked and orange light blinkinkg 20 times
I have the Canon Pixma ip4200 printer. I accidentaly forgot the cover open (trying to change cartridges) for more than 10 minutes I think, and then the header it "locked" at the right handside of the printer, not in the middle, and I cant unblock it, and the 2 black cartidges are missing from the header. The orange light of reset blinks 20 times (error 6500). Just before it was working the printer (printing washy dvd's, but probably due to run out of BK and PGBK). So I went to check cartridges, and thats what happened. Thanks a lot!
  • 390 Answers
SOURCE: Canon Pixma MP150 - Error code E7, light C flashing
Try removing cartridges and manually claening the heads with cleaning solution and cotton bud (q-tip) replace. Print. No luck? Now try uninstalling and reinstalling printer.
Posted on Aug 11, 2007
Mike258
  • 1498 Answers
SOURCE: Canon Pixma ip4200 printer, error 1414
Hello there,
I've gotten in touch with Canon and have something a little different to try. At the very least the error should change. (Sorry, gallows humor). Please read this entire response before taking action.
After the upcoming test procedure, I have included a link and procedure to contact Canon tech support. The assure me they will replace any faulty tanks.
The purpose of this exercise is either rule out ink tanks that are behaving or isolate the one(s) responsible for the 1414. You should write down the results of this test. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error 1414 Ink tank problem on my Canon PIXMA iP4200
The error won't go away.
I have replaced the <color in question> tank, reseated it, yet the error remains.
You will also need to list what inks are being used in the printer. State the type of ink that is being used and the order that the tanks are installed in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Mike
If you could take a moment and rate this response, I would appreciate it.
Posted on Jul 31, 2008
old marine
  • 2097 Answers
SOURCE: Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Posted on Oct 14, 2008
  • 39 Answers
SOURCE: Canon pixma ip4200 error 6500
Maybe you need yo update your drives for it.
Go to the website of the manufacturer and see if you need to download something for it.
If not please feel free to reply and I will be more than happy to help.
Hope this helped
-Ryan
-Please Vote if this helped.
Posted on Feb 18, 2009
huntwolfe
  • 20 Answers
SOURCE: Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Posted on Oct 02, 2009
How can I reset the waste ink counter in the printer Canon Pixma IP4200 ?
you can reset it following this procedure:
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold POWER button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
Then you should do this http://erkinson.altervista.org/blog/2010/canon-ip4000-disassembling/
May 14, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
How do i fix "Waste ink full" to resume printing
Hello there
Canon Pixma iP4200, Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction. :
Look at the table below:
· 1 led- Orange – Service test print 1 times – Orange – Service test print
· 2 led – Green – EEPROM information print 2 times – Green – EEPROM information print
· 3 led – Orange – EEPROM initialization 3 times – Orange – EEPROM initialization
· 4 led – Green – Waste ink counter setting 4 time – Green – Waste ink counter setting
· 5 led – Orange – Destination setting (Press Power > Press Resume 3x) 5 times – Orange – Destination setting (Press Power> Press Resume 3x)
· 6 led – Green – Print head deep cleaning 6 times – Green – Print head deep cleaning
· 11-13 led – Orange, Green, Orange – Return to menu selection
· 14 led – Green – Left margin correction 14 times – Green – Left margin correction
  1. Turn off the printer POWER button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Orange light 4 times
Press and hold the "resume" button for 5 seconds. If this not help, open the cover and replace the cartridge who not light.
Sep 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
DVD label won't print, tray is rejected, 6 orange flashes (cover is supposed to be open)
I've got this printer with no problem.
Make software ready to print with dvd cover closed and press print wait until software tells you to open drawer the place tray up to white arrow's and press print
Should work
Apr 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Waste absorber is full in canon iP4200?
Follow this instruction:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 of times.
5) Then press the Power button, then press it one more for turning off printer.Restart the printer and it will printing again.
Jan 10, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Flashing Error
Hi , the printer need to reset , the factory setting are already exceed the copies of used , so the printer need to reset to obtain zero counter .try to visit the web site of canon fixma .com.
Feb 21, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
