Question about Video Game Consoles & Games
Hi need help for Legend of Spyro - Eternal Night. Have got to the four temples and in each one there is a small spiderand just beyond it a locked door. Nothing seems to hurt the spider, but it seems that it is the link to unlocking the door. Does anyone know what to do please.
  • 199 Answers
Back out in the Temple level again, walk forwards and some apes will appear.
After killing the pair of soldiers that attack first a couple of Death Hounds
will appear. These are fast moving enemies that will charge into you from afar,
so watch out for them. Another pair will arrive and then you'll see a short
scene of a large ape leader jumping down. His attacks, if they hit you, will
freeze you on the spot. Use fire breath to get out of it quickly, jiggling the
analogue stick is a bit slow. Once you've taken care of the Leader and the
soldiers and hounds that appear some bombs will helpfully smash some rocks for
you.
Go over to the right and push the first statue into position at the end of its
track. Then off to the left and push the second statue. Jump on top of the
statue to reach the part above. Stand on the circle and the door will open.
Activate Dragon Time and wander into the building.
Dead ahead there's a torch to flame (to the right is an unlimited green gem
cluster if you run out of magic) and down the hall to the left you'll find
another couple, the last of which will open up the big door. Go through that
very same door. Avoiding the large hole in the floor, continue on through this
passageway to where some soldiers put out the torches. Kill them and their
leader and reignite the torches. The door will reopen to go through.
Go right and outside. Kill the spider, once it's down you need to tail strike
it (aka head bash or horn dive) so that it doesn't get up again. After killing
it turn to the left and jump up onto the ledge. Stand on the little platform in
the far corner and look up to the left. Jump from the first branch onto the
hexagonal pillar, then onto a tree branch and then across the path to Quill
[03/40].
Continue on along the path again and light the three torches ahead, jumping up
the steep platforms to reach the last one. The door will open and a Snail Rider
will enter. Flame the snail and then jump and air melee the rider. Make sure to
jump back after a few hits as the snail will pop out again, hitting you in the
process. Keep repeating this until they're dead. The door will open.
Go through the door and along to a fire torch which you'll need to light. The
other two are just ahead, one to the left and the other behind a vine wall
which you'll need to smash using your melee attacks. Once lit, in will charge a
couple of Death Hounds, take care of them before moving through the door. Go
down the corridor to the left carefully, the floor will shake and collapse.
Glide over the gap to take out the leader throwing ice bombs at you, as well as
the couple of soldiers he summons when you reach him. Now turn around and go
back over the second gap and look down into the first. You should be able to
see a green thing twirling around down there. This is the first of five Magic
Relics, Magic Relic [1/5]. Jump back out of the hole again and go through the
door you just opened.
Smash down the vines blocking your way and go right (left to some Blue Spirit
gems) and head outside. A Commander and a pair of Death Hounds will appear.
Kill them, watching out for the Commander's green blasts that he sends out
every now and again by hitting the floor. Then you need to light the three
torches. One to the right of the entrance, one to the left and the last you
need to use the platform the left one is on to reach.
The correct direction of travel once inside is to the left. Smash the vines and
jump over the gaps, watching out as the floor is all ready to collapse, even
just by gliding over. Once at the other end you'll reach a check point. Tail
Strike the vines and you'll fall through into a spider den. Watch out for their
spinning, and remember the easy way is to simply knock them up into the air
once and Tail Strike them when they're down or you'll keep on having the attack
them. You only have to hit them twice. Once the first two are dead another pair
will smash their way in, handily making an exit for you once you're done with
them.
Follow the path out and smash the vines in your way, you'll reach some Toad
Weeds. Kill them and get onto the bridge just past, turn to the right and you
might just notice a red/orange spinning icon in the distance. Glide down to it
and collect Health Relic [1/5]. Use the roots on the wall to get back up, the
last one requiring a sudden change in direction. You'll get back up on the
right side of the bridge, keep going.
You'll encounter a spider lickety split, kill it and jump up the platforms
beyond and inside again. You'll reach a room with five hexagonal pillars of
varying size. Exactly positioned so that you can reach the very highest one and
collect Quill [04/40].
Continue on to the right, watch as the pillar topples over forming a bridge,
and immediately avoid the spider's attack. Cross that new bridge and kill that
spider (I say spider, it's only got six legs). Down the path behind it and up
to where a Snail Rider is sitting waiting. He'll summon a load of Toad Weeds to
help, ignore them whilst going straight for the big target.
The vine wall will smash by itself allowing you through. Jump over the broken
bridge and follow the leader dancing about on the other side upwards. At the
first jump before turning to jump up again continue along a bit and round the
corner you'll discover Quill [05/40]. Get back to jumping upwards. As you enter
the passageway watch out for the rolling barrel. It will explode if you bump
into it so just jump over, Dragon Time if you can't seem to time it right. Kill
the leader standing about halfway through the tunnel and then jump straight off
the end.
Glide down to the torches below, light the three of them and get back upwards
to continue along the path above. A couple of hounds and a leader will run in
to get killed. Once past them there's a Commander in the next room awaiting the
same fate. He'll summon three soldiers to help him though, and once the four of
them are dead another few waves of soldiers and leaders will smash their way
in.
Once they're out of the way some spiders will appear. Jump up the platforms
once you've squished them and you're saved again. Use the branches on the left
to get over the thorn pit where a couple of spiders will promptly attack.
Avoiding the attacks of a third long distance spider you'll then want to glide
over some more thorns using branches, you might need Dragon Time in order to
avoid getting stopped.
There's another Snail Rider up ahead along with a crafty catapult and and ball
for firing in it hidden beneath some vines. Kill the Snail Rider in the usual
manner and melee the vines holding the ball in place. Drag it up the slope to
the catapult, stopping only to kill the Toad Weeds that appear, push it into
the cup and melee it to trigger. Use the platforms below to get up to where you
smashed and keep going.
Watching out for the ice bombs, glide down to the left, up the platform, light
the torch and glide over to where the leaders and commander are. Kill them,
light the torch and finally glide over to the last torch in order to open the
temple door, making sure that none of the apes have put out your torches.
It's a quick trot along a long thin path, jump over the spikes onto a tiny
platform in the middle of them and again to a branch sticking out, one more
platform and then to safety. Wander past the gems and into the darkness at the
end. Finally.
There's a few soldiers and a couple of leaders to kill before you get to the
boss fight.
Posted on Jan 11, 2009
I have a playstation Model scph-75002 and I have just purchased Spyro Eternal Night whenI put it in my Playstation it told me I need a format disc where can I get one
Seems you have the right device for the game, I supose other games do work? it can be that the game you bought is faulty, can you try it in another ps2`?
Apr 17, 2008 | Video Game Consoles & Games
Keep getting stuck all available codes will help
Hide at the edge of the map for two of the swipes (listen for the sound) and run in for the third one. Jump and glide just after he puts his head down to avoid the swipe, and then start headbutting. After three of those he'll start pounding the ground, but if you keep jumping when you hide you should avoid most of it. Ludicrously tricky, but possible.
May 31, 2009 | Sierra Entertainment Spyro: Eternal Night...
unlimted life seems like the cheat you need. Just hold L1 while playing then press: right, right, down, down, left. this will give you unlimited life and should help out. Also look up some cheats and walk throughs on Google, they always help
May 21, 2009 | Sierra Entertainment Spyro: Eternal Night...
Cant beat the boss
You will have three fights. In the first fight, be sure that Spyro and Cynder are in their gold armor. You may want to put Cynder in Black Armor, because her Fury Breath is ten times better in that one. Depending on how you are playing ( By yourself or with someone) Use Cynder's poison or fear scream to stun Malefor, then use Spyro to hit him. If you do it right, green magic gems and red health gems will fly out of Malefor. He will then zoom past you and start throwing those damn fire balls at you. Use your spinning action to spin around them. Do the same thing, using Cynder's posion and Spyro's electricity to fight him. It really is key to actually HIT him and not use just magic. At the bottom right hand of your screen, you should see Malefor's health begin to deteroiate. When it gets low enough, it will go to a cutscene, where you will have to press different buttons. If you do it correctly, the world will begin to destory and that leads to the 2nd fight. In this fight, it took myself and my boyfriend ( we played it as two player) forever to pass this part. Malefor will shoot ice and purple fire balls at you. Again, use your spin action to get around these. Be careful though, because the purple balls will target either Spyro or Cynder. Use your magic from time to time, but this is when you really want to HIT Malefor. Use Cynder's poison and Spyro's electricity, BUT Use combos, ( Mainly the Square button) and really just beat the **** outta Malefor. Towards the end, you will want to go into Fury Mode. If you dont know how to do this, hold the triangle and square buttons together . Just hold them, dont press them rapidly, just hold them. Spyro and Cynder willl form purple and blue balls around them, then shoot beams of power out of thier mouths. (( Malefore's health needs to be low enough for you to do this). It will then go to another cut scene. You will have to press the buttons in the order they appear on the screen. Okay, now you are at the last fight. Malefor will have a purple bubble around him. HIT THE BUBBLE TO REBUILD YOUR FURY METER. Once your fury meter is full, go into Fury mode again and then it should go into another cut scene. Press the buttons in the order they appear on the screen and there you have it. It will show the ending and then the credits. Wait after the credits for a special scene. Hope this helped you alot,
hope that helped
Apr 19, 2009 | Sierra Entertainment The Legend of Spyro:...
Can't get into door in first temple with 4 windmills
Obtain the Gale boomerang by defeating Ook. Then go back to those fans and look at the pattern on the floor. Target and lock on all four so the Gale Boomerang moves in the "Z".
Mar 29, 2009 | Nintendo The Legend of Zelda: The Twilight...
Cant get past level spyro dawn of the dragon
either your trying to hard or not enough just take some time
Mar 13, 2009 | Sierra Entertainment The Legend of Spyro:...
Spyro the eternal night
hide in a corner until it will take it's third swing(before the Earth Dragon does that get close to it and double jump it's swing.) Then attack.
Jan 01, 2008 | Video Game Consoles & Games
Spyro the eternal night for DS
omg tell me about it i cant beat him!!!!1
Dec 30, 2007 | Video Game Consoles & Games
Video Game Consoles & Games Logo
91 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
