HP PSC 1315 All-In-One InkJet Printer Logo
Anonymous Posted on Dec 01, 2012
Hp 1315 printer alignment message comes on computer screen each time computer is turned on
I've done an alignment a number of times but each time i turn on my computer a message box comes up that says " if you have changed ink cartridges you should do an alignment" , or something to that effect. How do I get rid of that annoyance?
Omer M. Elhag
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Dec 02, 2012
Omer M. Elhag
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
7180
Points
38
You have to complete the alignment steps by scanning the page after it prints (put the printed page on glass and press scan button) . i hope that is helpful
  • Anonymous Dec 02, 2012
    Thanks for trying to help, but I had done the alignment process about 8 times to no avail. Now somehow I got it to work properly. I wish I knew what I did differently that made it work so I could help someone else, but unfortunatly I don't have a clue.
5 Related Answers
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Jan 11, 2009
SOURCE: ALIGN HP 1510 printer
1Verify that the printer is turned on. If the printer is not on, check to ensure the power cord is securely plugged into a working electrical outlet, then press and release the power button one time. Wait for a few seconds while the printer powers up. Step2Lift the paper output tray. Load the letter or A4 unused plain white printer paper into the paper input tray. Lower the paper output tray. Step3Double left click the "HP Solution Center" icon to open the application. Single left click the "Help and Support" tab. Single left click the "Printer Toolbox" link. Single left click the "Align Print Cartridges" option to open the "Alignment Page" window. Single left click "Align." Step4Wait while the printer prints an alignment page. Examine the alignment page carefully and select the option that appears to be most correctly aligned. Select that option by single left clicking the corresponding option on the drop-down choices in the alignment window. Step5Single left click the "Done" button once you have entered all appropriate options. Wait while the printer prints a confirmation page. hope this helps
Anonymous
  • 7 Answers
  • Posted on May 27, 2009
SOURCE: Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Jan 21, 2010
SOURCE: I can't get rid of the "align cartridge" message.
just complete the process after align test page just place the paper on glass and scan it .it will complete the preocess.
Anonymous
  • 111 Answers
  • Posted on Apr 13, 2010
SOURCE: HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Anonymous
  • 54 Answers
  • Posted on Jun 25, 2010
SOURCE: ink cartridge alignment
hi....when it ask for align it will print one page with lines etc. After printing just place the paper on scanner of the printer . printing side down and press the scan button..it will blink for some time and stop. now when u print anything on it it will not print align page. just remember that whenever u change the cartridge u have to repeat the same process..... Vikas Sharma....Computer Solutions, [email protected]
Cannot delete print job from hp photosmart 7520
Throw this printer in garbage & buy a new 3 years warranty printer.
I did the same thing.
Please do not waste your very valuable time behind solving issues.
1helpful
I want hp psc 1315 all-in-one printer scanner copier Software & Driver
Here are thedrivers . When you click on the links, give it a minute and they will'pop-up' on your screen. When you click 'Save' the driver package willbegin to download. OS Type Version Date Added File Size File Type Download Link (About) Windows XP Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows XP Printer Driver Download Windows 2000 Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows 2000 Printer Driver Download Windows XP 64-bit Driver 1.0 - Beta 2008-05-10 58.43 MB exe HP PSC 1315 Windows XP 64-bit Printer Driver Download Windows Vista 64-bit Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista 64-bit Printer Driver Download Windows Vista Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista Printer Driver Download Windows 7 Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 Printer Driver Download Windows 7 64-bit Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 64-bit Printer Driver Download ALTERNATIVEDOWNLOAD LOCATION.
Note: These are LARGE files and may take some time to download.
Save the driver file somewhere on your computer where you will be easily ableto find it, such as your desktop.
After downloading, go to the location where you saved the file and double clickon the file. Then simply follow the on-screen instructions for installing thedriver.
HPPSC 1315 Windows 7 Printer Driver Download
HPPSC 1315 Windows 7 64-bit Printer Driver Download
THE HP SOFTWARE IS AVAILABLE THROUGH YOUR OPERATING SYSTEM. ON WINDOWS CLICKSTART AND THEN SELECT THE WINDOWS FAX AND SCAN ICON.
Software: Download optionsand information Description: clip_image002.png This software installs a copy of the help files onto your computer. Install this software if you did not install from the CD or if you did not install the full featured version of the software. Do not install this software if the help files for the HP PSC 1315 are already installed on your computer.
To see if the help files are already installed on your computer, check the following destination:
Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help.
Windows Vista: On the Windows taskbar, click the Windows icon, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help. Details andspecifications File name: clip_image002.png MaggiMinus_Installer_24Nov08.exe [1/1, 24.91M] System requirements: clip_image002.png No additional prerequisites Released: clip_image002.png 2008-12-04 Version: clip_image002.png 1.1 Compatibility: clip_image002.png Microsoft Windows Vista, Microsoft Windows Vista (64-bit), Microsoft Windows XP 64-Bit Edition, Microsoft Windows XP Fix/Enhancement: clip_image002.png Updated the file to make the help files available from the Windows Start menu after installation is complete.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-66177-3&lc=en&dlc=en&cc=us&os=228&product=374568&sw_lang=&key=null&site=null
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_cd01d4e4178e5a11
3helpful
HP PSC 1315 Prints test page every time printer is installed
Hi Jay,
This is mike, actually the problem is that that printer has not completed the aligning process, as a result the printer is printing the test page (Alignment page) every time when you turn it ON. So, I would suggest you to let the printer prints the alignment page and check whether the printer prints the page with all colors and it printed fine, once it is done, disconnect the USB cable behind the printer and then place the alignment page on the scanner glass by facing down the printed page downwards and press the scan button. This start the alignment process and the scanning process will be completed once the ON light is stop blinking. This will complete the alignment process.
Once done try to turn off and turn on the printer and check for the result. This should resolve the issue.
However, if the issue persist, then please revert back to me. Be sure that you use the HP genuine ink cartridges, not refilled nor re-manufacture.
My HP 1315 keeps printing the alignment page...many times, even t
clean the feeder roller for possible debri and clean the encoder strip located at alongside with the carrier carttridge. It is usualy the done that guides your cartridge for alignment. Also try to inspeact and clean the encoder wheel located at the leftmost side of your printer. This is the timing wheel for paper feeder.
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
[email protected]
3helpful
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
Hi Mahdavi,
Steps
Thanks
Rizwan
[email protected]
HP psc1317 printer - wasting paper on power on by printing test paper
If the alignment is not done sucessfully then the printer prints a test page every time the printer is turned on, so it is recommended to align the printer and the cartridge.
Try th steps again in the bellow link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00109818&dlc=en&product=374568
Good Luck
k24674
Grand Canyon Tech
Grand Canyon Tech
