Question about Samsung R530 Notebook
Is there an easy way to adjust briteness on my samsung r530
Even when my batt was 93% when i unplug from the mains the screen dims,as soon as i re plug the screen brightens. can u help plz?
  • 564 Answers
If you're using windows 7 go to control panel and choose power option and you'll be able to change settings (there should be a slider for battery and plug in options)
Posted on Dec 04, 2012
2 Suggested Answers
SOURCE: i have a new samsung r530 laptop; was working on
Press FN F5
Posted on Jul 19, 2010
How to replace the Enter key on Samsung NP-R350
replacing the whole keyboard is the best idea for the small clips under each key will just never behave the same again ... keyboards are very cheap on eBay and very easy to replace do not let a shop overcharge you ... less than 100 say about 80 tops
Jul 05, 2014 | Samsung np-r530-ja04us - R530 Notebook Pc...
Cannot adjust brightness
Go to the battery icon. Right mouse click and choose Adjust Screen Brightness. Then down load the drivers for your laptop from Samsung.
Nov 29, 2013 | Samsung R530 Notebook
Screen is dim when power not plugged in
In power settings you will find the dim adjust, Your laptop has power settings you can adjust to your preference. That said, the default settings are usually set to a power saving that means when you unplug your laptop from th AC source your laptop will dim to the power savings settings and prolong battery life. Look in power settings by right clicking the power icon in the taskbar notification area and open the power options. There are many options to choose from I use High Preformance, but on battery it shorten battery life. If you need assistance just respond to this solution.
Nov 05, 2012 | Samsung NP-N110 Netbook
Lights on nobodys home
Unplug it, remove battery, hold power button 10 full seconds, reinstall battery, plug in and turn on. It should work fine now. If not, memory stick is likely bad.
Jun 09, 2012 | Samsung Np-r530 Np-r530-ja05us R530 Laptop...
Laptop samsung r530
see my solution posted on other question
May 25, 2012 | Samsung R530 22GHz Intel Core Duo...
Samsung r530 laptop goes back to log on screen if left idle for a few minutes
that is most likely the sleep mode on the screen saver
open with start button
control panel
display icon
adjust screen save settings for longer
and look to see what happens in power save mode for shutdown
should work well
let me know how this goes
R530 switchesoff
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the battery dropsoff to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 12, 2012 | Samsung R530 Notebook
I have lost Bios password on my Samsung R530. How can I get it back
Usually removing the internal battery in a laptop does not remove the BIOS password. However I have just done this on the Samsung R530 and it did remove it.
Remove AC power, remove main battery, turn laptop upside down and remove all screws, push up the little tabs at the top of the keyboard to unclip it and remove ribbon cable from motherboard, disconnect the 4 wire speaker plug and then pry open laptop from the front, pop the plastic lugs in the battery bay and remove the top facia.
Remove the small coin battery and hold the power button for 15 seconds making sure you do not have the AC jack or main battery installed.
Reassemble, turn on and you should be able to press F2 to enter setup.
Please thank if I helped.
Jan 22, 2011 | Samsung R530 Notebook
My laptop britness is not working properly
Is it flickering, or just having promblem adjusting the brightness? If is is flickering, it could be a loose wiring connection. If it is not adjusting brightness, check via using your FN keys, then try clicking the battery icon in your taskbar and adjust brightness through it. If nothing happens, it could be your screen inverter.
Jan 20, 2011 | Samsung R530 Notebook
Samsung R530 Notebook Logo
185 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
