Question about Gemmy Life-Sized Animated Santa
What voltage power cord do I need for my 5 ft dancing Santa?
SOURCE: I have a 5 ft tall singing dancing santa claus
Push his shoulders down together then release!!
Posted on Dec 14, 2010
SOURCE: I have a lifesize grinch
if you have the same on as I do, gently pull off his head - there is a large dial that you turn to unlock him into the standing position.
good luck
Posted on Dec 18, 2010
Testimonial: "Thank you so much,I would never have figured that out..... Peggy !!!!!!!!!"
  • 5370 Answers
SOURCE: I have a walmart dancing
The shoe is held onto the base with four small screws. With Santa placed on his back, remove the screws and lifting up the shoe to look at the PCB hidden below it. Each set of wires going up into Santa connected to the PCB via a mated connector. There check the wires.Remove this wires and reconnect.
Check the wires as follows:--
GREEN/BLUE pair: This is used to activate Santa's side-to-side 'dancing' motion. The green connection is ground. The blue connection had 7.5 volts DC. But when you measure it again at a different time, the blue connection will show 12 volts. This is why there is mystery potentiometer to control the voltage.
Now how the potentiometer is connected and how it controls is as follows:---
GREEN/GREEN pair to potentiometer: It seems that this variable resistor controls the speed of Santa's side-to-side "dancing". Turn it low, and you'll get a performance worthy of a nursing home. Turn it high, and it'll be jerky and could topple Santa over given the right conditions. Effective voltage range to the motor (which controls the speed) seems to go from 5 to 12 volts.
the motors and speakers are analog devices that are connected to the main PCB.
the main PCB actually acts as a digital to analog converter, and the real smarts of the Santa are in a tiny little computer chip.
Santa's personality chip.
Soldered onto the main board and sticking up from it at a 90 degree angle is a small 15 pin PCB with a single custom IC. This contains the 'personality' of the Santa. All the sounds are recorded on the board, and all the actions are digitally recorded.
Remove the small board, and you have direct access to Santa's digital controls. This makes it very easy to operate from a microcontroller or even a home PC. Going through the digital controls, you take advantage of the built-in motor control electronics, volume control, motion sensor (and motion sensor enable/disable switch), and start/stop button.
Now here the motor connections needs to be checked.Also for internal pcb and motor connections step by step.Click this link directly and read the instructions.
http://technoanswers.blogspot.com/2011/01/walmart-dancing-santa-details.html
This will help.Thanks.Helpmech.
Posted on Jan 15, 2011
SOURCE: I have the 48" gemmy singing, dancing santa. We
I have the same problem. Ever find an answer?
Posted on Nov 28, 2011
  • 173 Answers
SOURCE: I need a new power plug for my 5ft singing dancing santa
there are so many out lets ask on google chrome according to your city and country.
Posted on Dec 13, 2011
Please help where do i get the poer cord for the dancing santa
Probably a simple 'figure 8' cord. Look at the images and order from ebay. Can also get from good electrical or electronics wholesalers, even Best Buy or Walmart.
power cord types Google Search
Dec 05, 2016 | The Toys
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
Dec 01, 2015 | Toys
My dancing Santa needs a power cord where can I order or buy ? Thanks
See if you can find the correct voltage input. It should be printed close to where you plug it in. Also note the type of plug that it has.
You can then get a matching power supply or a universal power supply from most any store that has an electronic department.
Dec 10, 2014 | Cars & Trucks
I need to find a replacement cord for my animated dancing and singing santa. Can you help me locate one. I understand that it is a special cord.
I wonder if it is the same as the cord for desktop computers and flat screen tvs. If so you can replace it from any computer store.
Nov 18, 2013 | Gemmy Life-Sized Animated Santa
Singing dancing Santa won't stop dancing
My neighbor just gave me 1 of these... needed the adapter... 4.5 Volt 800 mA and be sure to get one where you can reverse the polarity if necessary. (polarity is: + ---O---- - ) I had to do some "modifications" to the base as my adapter had an "L" base & wasn't long enough - straight adapter would have been better... Santa wouldn't stop singing/dancing- hmmm. Cleaned the motion sensor lens and then had to cover the modification hole in the base to completely darken the interior of the base. Viola now the motion sensor works... is driving the dog crazy!!
Nov 06, 2012 | Gemmy Life-Sized Animated Santa
Dec 13, 2011 | Gemmy Life-Sized Animated Santa
Gemmy Life-Sized Animated Santa Logo
156 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
