Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Hair around wheels
My daughter has very long hair and no matter what vacume we buy, her hair always wraps aroung the beater bar and wheels and if not cut off or cleared will cause the belt to break. Is there a vacume able to pick up hair and not get entangled?
  • 548 Answers
No. I have 3 women and 2 dogs under my roof and have the same problem. My wife uses a Eureka vacuum that cost $140.00 and it seems to handle this better than our old Kerby.
We take a broom and swiffer and collect what hair we can from the bathroom areas, etc, before sweeping to avoid this problem.
Posted on Jan 11, 2009
My dog hair collects on my DC44 Animal. After using it on the rug it just wraps around the bar in excess. Please help.
Try turning off beater bar.but if theres so much hair its wrapping around bar u may need to use just the hose to remove the bulk first
Apr 09, 2017 | Dyson DC44 Animal Cordless Vacuum
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
Vacuum squeaking loudly!!!Help!!!!
Most likely has a bunch of hair wrapped around the beater bar. Get some scissors, razor knife and some needle nose pliers. Turn the bottom up and remove the cover and start digging the hair out. You may need a new drive belt too.
Nov 07, 2015 | Vacuums
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
How to make my beater bar on the dyson 33 turn?
Hair is probably still wrapped around one end of the axle. It's HARD to get all the hair out of there.
You did get the drive belt back on, true?
Aug 10, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beaters will not turn. I have checked all that I know too. Please advise.
Mine gets seized up with hair wrapped around the bearing points. Remove the beater bar and unwrap the hair.
May 31, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Brush won't turn.
Hi, W/D here.
You'll need to remove the base plate around the beater bar, and remove any hair that is around the ends of the beater bar. It tends to collect there, along with bits of string, ribbon, and such. When you're removing the hair, be aware of how the beater bar fits in the sockets that hold it in the vacuum frame; you have to replace them in the right way or the beater bar will rub.
Best regards, --W/D--
Aug 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hair around belt area
Design flaw. You have to clean that out regularly :)
Mar 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson animal
sounds like you may have alot of hair or thread wrapped around the bar, this can stop it if there is enough, have a look at the beater bar (brush)
Jun 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
101 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
