Question about Mitsubishi Heating & Cooling
Why my mitsubishi air conditioner msh-24n is not cooling
My mitsubishi air conditioner msh-24n is not cooling, we cleaned the filters and still bowls hot air.
  • 1214 Answers
SOURCE: Mitsubishi Air Conditioner FDKN Series leaks water after 30 mins
It could be one of two things -
1) The unit is not hanging level (assuming this is a wall mount, through the wall, or window unit), or
2) The condensate drain or trough to the drain is plugged/clogged/filled with trash.
Posted on Jan 22, 2009
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
SOURCE: not working probly two flashs then pause
The two flashes are telling you what's wrong with the unit. Take the cover off of the unit inside(evaporator) and there should be a guide on the panel with the wiring diagram. On this diagram there should also be a solution to what each blink means. One blink means this, two blinks mean that, etc... Hope this is helpful.
Posted on Mar 14, 2009
  • 34 Answers
SOURCE: Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Posted on Aug 11, 2009
  • 534 Answers
SOURCE: outside unit fan not turning no cold air inside.
Ok here we go. It is possible that the capacitor for that fan unit is out or the motor for that unit is out. Without the proper tools i.e. an electrical meter, there isn't really a way to test the unit. The remote should not have anything to do with the unit activating if the is a manual thermostat. I suggest checking to see if either the motor has gone bad or the capacitor has bit the dust. If you have the motor changed make sure to replace the capacitor
Good Luck on your repairs hope I helped you some\
Dave
Posted on Jan 08, 2010
Testimonial: "A very quick response with a helpful reply. "
My compressor on my mitsubishi msh 18nv has ceased. Is there anything I can try to fix it (eg a gentle tap with a hammer) before I spend a fortune to replace this compressor?
Sorry to inform you, you need to get a HVAc tecnision out too replace the compressor: Did a technision test the amps on the a/c unit? Why did the compressor ceaced?
Sep 20, 2011 | Mitsubishi MSH09TW Air Conditioner
I have a heat pump mitsubish MSH-12RV. It turns itself off after 1-2 minutes operation. Ihave cleaned the filters and re-set the clock. Any other suggestion?
If its not being turned off by the thermostat, sounds like it might be the low presure switch kicking it off due to low freon. You will have to get a HVAC tech to charge it back up.
Mar 14, 2011 | Mitsubishi Heating & Cooling
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
What is the refrigeramt capacity of the model
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 18, 2010 | Mitsubishi MXZ30TN Air Conditioner
Air not cold...model MSH-18NV no operating manual for remote . Not sure how to set to cool air when remote reads "I feel..." choices are cool dry or warm but when set on cool 20degrees, luke-warm air blows...
Hi FixYa team. After about 2 hours on the internet I managed to find a PDF file of the operating manual for my air con.
Thankyou for your prompt response. I'll be using your services again!
Jan 11, 2010 | Mitsubishi Heating & Cooling
Blowing our brown flakes.
you wouldn't see the mold, but you can smell it. Probably paint chips
Jun 16, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Not working probly two flashs then pause
Mar 14, 2009 | Mitsubishi Heating & Cooling
Mitsubishi MSH 18NV no heating or cooling
The fact that nothing is coming on indicates that there is possibly a problem with your incomming power supply or wiring to and from the inside evaporator to the outside condenser. If all in good order, suggest you find someone you know who can operate a multimeter and check if there is voltage going to the control board inside the evaporator unit. If there is then almost certainly the control board would need replacement.
Feb 05, 2009 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
