Question about Refrigerators
Amana PTC123B35AM How is the fan set to run continuously?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Dec 01, 2012
Amana 153G35XXXXAA condensing fan motor works but drops out when temeperature is reached and compressor continues to run for a couple minutes
Maybe designed that way. Unless it is not working properly and doing the job I would not worry about it. But you can always check with Amana
Sep 21, 2017 | Amana Refrigerators
Amana model ptc093d35ardb
search the option then click the install option then press run
Oct 23, 2013 | Microwave Ovens
Helo. Our Distinctions system's fan runs continuously, but the air coming through the vents is room temperature. What can I do?
If you have adjusted the thermostat setting and the compressor still does not run, you may have some wiring, compressor, overload, or capacitor problem.
Sep 10, 2011 | Amana Heating & Cooling
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
DOES ANY ONE REMEMBER HOW TO PROGRAM A AMANA PTH 093 B35 WINDOW UNIT TO MAKE THE FAN RUN CONTINUOUSLY? I AM IN HOTEL ROOM AND WOULD LIKE TO DROWN OUT THE CARS OUTSIDE ON THE INTERSTATE. THANKS
Press and hold up and down arrow at same time -press off twice to get into program mode (should read C1) -press heat button to scroll to C2 the use up arrow to scroll through options. You want to set it to read-out "On" then press off to set. This should be the continuous fan mode.
Feb 18, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
The fan does not work
If this is an Amana, the evaperator fan motor works through the defrost thermostat. If the thermostat is open (no continuity), the fan motor will not run. This is usually the solution for this particular brand. Replace the thermostat and once it satisfies (within 5-10 mins. of replacement), the fan should start to run.
Jul 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Our thermostat is set at hold with the fan on auto. The house and cool temp is set at 75 degrees, yet the fan will stay on CONTINUOUSLY unless I manually take down the temperature OR the outside temp falls...
it is ok to run your fan continously. constant air filtering as long as it pauses before a/c cycles on. will not use any more electricity than a toaster. is there a fan programing feature on t-stat. if so you will need to turn programing to fan off
Jul 30, 2009 | Amana Heating & Cooling
A/c doesn't cool -- froze up, then thawed, now it doesn't cool
I found an 800 # for Amana in the HD Warehouse catalogue -- 877-376-0214 -- and called to talk to a tech. He walked me through a diagnostic test, which was a matter of pushing some buttons on the very simple t'stat and fan pad (only a few buttons to choose from according to his instructions, which led to readouts where the temperature ususally is). He took note of what the readouts were and told me exactly what the problen was -- "the red wire that goes from the coil to the transistor board, because your numbers tell me that it's 188 degrees...and it's not, I hope" -- and then he took my address and mailed me one.
We'll see -- it should be here in a couple of days.
Jun 16, 2009 | Amana DigiSmart PTC123B35AM...
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
