Question about Music
I need a user manual for a Power Play KSP970 music keyboard and a power lead for it.
  • Barbara Coates Dec 02, 2012
    This keyboard is a 2009 model
Casio LK-100 keyboard is turning off often when chords are played, esp in lower octaves - seems like a short. Where might the short be - way to fix without taking the whole keyboard apart?
Sounds like a lack of power from the external "wall wart" power supply. Is it the correct one that can supply enough current for a chord to be played? (a chord will play more notes at the same time & pull more power from the supply in order to make the sound(s)) If it's the correct power supply or one of the correct current rating check the cable & the connector both at the end of the cable & where it plugs into the keyboard. Perhaps the lead has been tugged accidentally? / Damaged in some way? Turn the volume down a little & see if that helps - that will confirm the power theory :-) Good Luck!
Jan 17, 2017 | Casio Music
How do I factory reset my Casio CTK-2400 Keyboard?
You manual is here http://support.casio.com/storage/en/manual/pdf/EN/008/Web_CTK2400-ES-1A_EN.pdf
Interestingly...check out page EN-34...about the section on local control...Follow the directions to turn your sound back up... Good luck
Feb 23, 2015 | Casio Music
Keyboard wont play with ac adaptor
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Apr 04, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
Need user manual for MK-4902 midi keyboard
Use LMMS software on PC. You will need a MIDI to USB cable which you can get on eBay.
The manual can be found at:
webpages.charter.net/rochamalhada/MK-4902.pdf
Sep 20, 2012 | Music
I need a user manual for casio ctk 691 keyboard;casio ctk691 musical keyboard
Here is the link to the user manual
http://support.casio.com/en/manual/008/CTK691_EN.pdf
Feb 23, 2012 | Casio Ctk691 Keyboard
Casio ctk-501 the power input cracked on the curcit board i did a bypass wiring over the crack and it got power works again but only till i start playing a bunch of keys then the sound gets stuck and the...
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
Nov 17, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Do you need a computer to use the Novation UltraNova 37-Key Analog-Modeling Synthesizer
The Keyboard comes with inbuilt sounds (Approx 300 Presets and 200 user patches), so you can play it Live without a computer by simply taking AUX outs and it has a wall power supply adapter. You can also connect it to your computer via USB for additional sounds through VST instruments and Plugins. The USB also powers up the Keyboard without the adapter. Hope this helps.
Jun 06, 2011 | Novation UltraNova 37-Key Analog-Modeling...
I have a casio lk-44. I want to be able to play a song from the songbank, but just hear the background rhythm and not the melodies. I want to play the melody myself from the songbank. When I pick a song...
Not sure if your "booklet" is the full user manual... if not go to this site and go through their "hoops" and download the full user manual. It shows how to put the unit in the mode that merely lights the keys and plays the rhythm, unlike the "demo" mode.
http://www.retrevo.com/support/Casio-LK-100-Music-Keyboards-manual/id/467dj395/t/2/
Note the manual is free via the Retrevo site... just have some of those annoying hoopps like email address and entering numbers.
Mar 21, 2011 | Casio LK100 Lighted Keyboard With LCD...
What is the yamaha keyboard electric consumption
That varies depending on the model of the keyboard.
Download the user manual and look in the "Specifications"... You will find the power consumption listed there. Most will be UNDER 50 Watts.
Sep 28, 2010 | Yamaha Music
When I load a floppy with music styles into the
Not sure about your particular keyboard, but on the Yamaha Tyros the style will NOT start rhythm until you select start AND hit a chord.
The style doesn't know what chord to start with until you trigger it.
SOMETIMES the style has to be moved to a user space...
One has to read and then DECYPHIER how to work these synths... Spend a little time with the user manual, as hard as it is to understand.
Jan 12, 2010 | Yamaha Music
Music Logo
186 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
